Results 1 to 7 of 7
Thread: Solar blanket
    Solar blanket
    I have a new solar blanket I need to cut to fit my pool. I'm a bit overwhelmed at the thought of cutting this thing...it's 26x50!!!
    What is the best way to go about cutting this blanket? My pool is a free form shape also. I would love to get it on the pool since we have some warm weather coming this weekend. Should I keep the blanket in one piece or cut it into sections for easier removal? I probably will be taking it on and off myself.
    Also, will the Polaris work under the blanket?
    Thanks for any info on this!!!
    28,000 IG Free Form Gunite with quartz finish
    Pentair Quad DE filter, Intelliflo VS+SVRS
    Polaris 280, Sta-Rite 400K Heater-Propane
    Toms River, NJ
    151
    Re: Solar blanket
    Quote Originally Posted by mamasproject
    I have to do the same thing this year; I am looking forward to it, but I'm also not looking forward to it. The cover weighs 90 pounds dry (before the cutting).
    I can't comment on the best way to cut it, but because of my irregular shape, a reel for me would not be practical, so I plan to cut it to shape (while in the pool of course), cutting slightly larger than I need to so I can tweak it later and get the "tightest" fit. Afterwards I will cut it into three sections to make removal easier since I will also be doing it myself.
    From what I've read the polaris works fine under the cover, but the hose make push and pull a little on the blanket.
    45,180 gallon 26' x 53' IG Vinyl, irregular shape. Hayward sand filter / pump. Polaris AutoClear SWG, supplemented with a Hayward Automatic Chlorinator (In-Line). Hayward 400K BTU heater. Paramount "turnover" system. Polaris 480 PRO cleaner.
    Mar 2009
    Huntsville, AL
    156
    Re: Solar blanket
    My solar blanket only needed to be trimmed on one end to fit the steps. It cut quite easily with a sharp pair of scissors. Once you start the cut, you can just push the scissors to continue the cut.
    Be sure to put the blanket in the pool with the bubble side down. It is a real pain to flip it over if you are alone (not that I would know of course...)
    Good luck!
    Gordon
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    Jan 2009
    Cupertino, CA
    1,966
    Re: Solar blanket
    My Polaris has no problem being under the bubble wrap. In fact there's less spray from the tail now.
    With a new cover I'd lay it out on top first, then cut to fit. Remember a new cover will likely stretch some after you put it on, as the folds relax and the warm sun makes it expand a little; what I did was lay it out one day, cut the next. That was in March or so; along about July I needed to trim it a little more.
    --paulr
    BBB "Intermediate Swimmer"
    Re: Solar blanket
    I have an oval pool, bought a rectangular cover, let it sit for a day on the water, then cut out the corners. Since I remove it myself and put it back on myself, I cut it in half. Laid it out in the yard and sliced it right down the middle with a razor knife. Sooo much easier to remove in two sections. Remember, the covers get heavy when covered in water. Also, this way, the kids can play in the shallow end uncovered, and I don't always have to remove the section over the deep end if they don't use that side of the pool
    20k inground vinyl oval, Hayward super pump 1.5 HP, Pacvac 36 DE filter, Hayward inline chlorinator, Brand new liner 2009. 1st pool ever owned.
    jmills's Avatar
    Jul 2007
    Billerica MA
    36
    Re: Solar blanket
    The kid in me would find it irresistible to swim under that half cover.
    12' x 20' Intex Oval Frame Pool, AG
    Waterway 1 hp TWM Cartridge Filter
    4' x 20' solar panel
    41' water depth
    4393 Gallons according to the box.
    Mar 2009
    Huntsville, AL
    156
    Re: Solar blanket
    Quote Originally Posted by jmills
    That is a good point. It seems like you should be able to push the cover up and get a breath, but it doesn't always work that way. Kids might get into trouble thinking they can -- do keep an eye on them.
