Results 1 to 7 of 7
Thread: removing water, SWG water and grass/plants
    Hurricane Gio's Avatar
    Apr 2010
    Coral Gables, FL
    197
    Ok, we get a TON of rain here in SFLA and again the pool is about to crest so I need to get some water out.
    How bad is the pool water for the grass, shrubs, etc? Water comes for a SWG.
    I have a 100ft hose, so I can dump to one side of the house where its coral rocks and dirt or out into the street.
    Its against the law here to use the storm drainage system.
    Thanks
    8,000 Gal, 11 x 26.8ft Shotcrete Pool with "Cool Blue" Diamond Brite by ESSIG Pools with Artistic Pavers Deck
    Goldine AQL-PLUS w/Aqua Pod, Aqua-Rite T-CELL-15 SWG, Pentair WhisperFlo High Performance 1.5HP, 2 speed pump, Pentair IntelliBrite,
    Pentair 100sqft Cartridge Filter, 6 Pool returns, Skimmer and 2 Anti-Vortex Main Drains
    Pool's completed build 2/2010
    Jul 2008
    Solon, Iowa
    170
    Re: removing water, SWG water and grass/plants
    The grass that receives my backwash water seems to thrive in the summer.
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
    On the east coast there are hardly any issues with salt at SWG pool levels. In arid areas the salt can build up in the soil slowly over many years, but anywhere that gets a reasonable amount of rain is fine with dumping pool water just about anywhere you would put any other water.
    Quote Originally Posted by Hurricane Gio
    Thanks
    We sure did get a lot of rain down here today didn't we!.... Then I came home and find that my 11 year old was adding even more water to the pool....He wanted it to go "to the top"....
    I have occasionally dumped my pool water (I also have a SWG) over the last 5 years. Never had an issue with plants or the grass and that includes last year when my salt level was over 5000 after a bad cell/reading and I had to dump 1/3 of my pool.
    South Florida. 20,000 gallons; 16x35 rectangular gunite; Pentair Intelliflo VF Variable Speed Pump; Hayward cartridge; Aqua Rite SWG. Dolphin Oasis Z5 Robotic Pool Cleaner; Kopec 540sc Electric Heat pump pool heater; Pool built in Spring 2004.
    Apr 2010
    Coral Gables, FL
    197
    OK, thanks guys. So I assume that the chlorine in not harmful either then.
    Apr 2010
    Coral Gables, FL
    197
    Quote Originally Posted by johnd13
    Yes we did! My water rose 4" top even at the top of the coping, but not quite spilling out. I ran the dumping for 6 min to get the water out. I flooded my street since the ground was saturated.
    We run a hose to a sewer cleanout. Keeps the water out of the yard and flushes the pipe(s). Not adviseable if you have a septic system.
    16K gallon, Pebble tec, beach entry. Two 1 hp Pentair Whisperflos. One for Paramount MDX2 main drain, Paramount debris canister, and Pentair CCP 520 filter. One for skimmer w/sock and Paramount PCC2000 in floor cleaner. 3/4 hp Pentair Pinnacle for waterfall. Fiberstars fiber optic pool lighting. Aqua-Logic AQL-P-4 control panel with wired remote in the house. SWCG system that is not used. Ultra-Pure Ozonator that is not used.
