Results 1 to 14 of 14
Thread: sand!!!!!
    Jan 2010
    Randleman,NC
    590
    sand!!!!!
    How often should this be changed ,4th summer of use!!!!
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Feb 2008
    Denton, TX
    5,061
    Re: sand!!!!!
    Are you noticing problems with your filter such as poor water clarity or high filter pressures despite backwashing? Or, are you just wondering if it is time to change it?
    Some folks change their sand every five to seven years and then, some folks never change their sand. I don't know of any official time-out length for sand.
    If you are having problems with your sand filter not doing it's job despite regular backwashing and you know that your water balance in check, there are some things that you can try. You can open your filter and check the sand bed for channeling by following the directions posted in this thread...
    my-sand-is-channeled-how-to-fix-it-t7626.html
    You can also try adding some DE to your sand filter as this has been reported to increase the efficiency of the sand filter in capturing the snaller particles that normally pass right through the sand bed. Here's a sticky on how to add DE to you sand filter...
    pool-school/add_de_to_a_sand_filter
    Of course, if you want to, you can go ahead and replace the sand entirely. It's a messy job though and you must be very careful not to damage the laterals inside the sand filter during the process, lest you end up with a more expensive maintenance item to deal with than you originally bargained for.
    Hope this helps. Others may be along to add some other ideas.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: sand!!!!!
    As 257 says, lots of opinions on the sand
    We have a sand filter with 4 YO sand and have no plans to change it.
    Kinda, if it ain't broke.....
    You're done SLAMing when:
    Jul 2009
    London and France
    574
    Re: sand!!!!!
    The sand in most peoples filters is thousands if not millions of years old. Give it a good clean/soak with chlorine and try air scrubbing it on back wash using a shop vac on blow. It will really lift the sand and it will seem to boil but boy does it clean the sand up.
    You could buy an acid clean wash from a pool store but never use this at the same time as the strong chlorine its dangerous.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: sand!!!!!
    In the my-sand-is-channelled link that 257 posted above, notice that waterbear recommends the deep cleaning he describes be done yearly.
    Jan 2010
    Randleman,NC
    590
    Re: sand!!!!!
    Thank's,just wondering !!It has been fine..I stop by the pool store today to pick a bag of sand to drop in my step's..I asked he said every 4-7 yrs..I believe I will leave it for another year or so
    Jul 2009
    London and France
    574
    Re: sand!!!!!
    Yep, just believe what the pool store says and you won't need this forum ever again
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Re: sand!!!!!
    The sand in your filter is like a rock in a moving river. Over time the pointy edges become rounded from the constant water flowing over it. The more rounded the edges get, then less it filters out the tiny particles.
    my personal opinion is every 3-5 seasons. 3 for those who run the filters non stop and 5 for those who run the filter 8-10hrs daily.
    Thats just my opinion though...
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    Jan 2010
    Randleman,NC
    590
    Re: sand!!!!!
    Teapot I take the pool shop with a grain of salt,I'm just going to wait and see how it goes...never had any problems with it
    Jul 2009
    London and France
    574
    Re: sand!!!!!
    Quote Originally Posted by Heckpools
    Yep, I believed that too, until I saw an electron microscope picture of freshly cleaned 10 year old sand from a commercial filter that had just as many points as the fresh sample next to it. It can become rounder and smoother with alginate biofilm build up but that was removed in the commercial washing process (acid clean and air scour plus wash with a cleaner)
    So save your money!
    InTooDeep's Avatar
    Apr 2010
    Lake Wallenpaupack, PA
    9
    Re: sand!!!!!
    My local pool store actually recommends changing it every year!
    24' Round A/G 14,500 gallons, Hayward HeatPro HPABG Deluxe 60K BTU heat pump, Hayward EC50AC DE filter w/1HP Matrix Pump
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: sand!!!!!
    Quote Originally Posted by kplaster
    Give it about 30 more years :0)
    Some say 4 years, some say never.. I say never unless you are running into trouble which is very unlikely the sand's problem.
    I usually change the sand when the filter has a major breakdown and needs to be replaced itself.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Jan 2010
    Randleman,NC
    590
    Re: sand!!!!!
    If it ain't broke don't mess with it...I haven't had any problems just was wondering if I should do it..Thank's for all the advice!!!
    Jul 2009
    London and France
    574
    Re: sand!!!!!
    I don't quite agree with that, it does become sticky and pebble into balls which allows channels to develop. So a good clean is necessary from time to time but changing it, waste of money unless there is a problem (calcium biuld up etc) or you are changing for something possibly better like Drydens AFM which I am experimenting with.
    http://www.afm.eu/
