Thread: Is My Decking Really Kool Decking?
    Aug 2009
    North Central Texas
    1,358
    I'm going to post a picture tomorrow. There is a current topic about delamination of Kool Decking. Another person commented on theirs being a certain thickness and delamination. A friend of mine has some delimitation on hers that she thinks is from her DH pressure washing with too much pressure over the years. (her pool was installed in 89)
    My pool and decking was installed in 81. There are no issues with it except for a few cracks at the deep end where there is the 12' drop off and the deck heaving in several areas up or down around the brick coping. I was looking closely at it the other day, inspecting some areas from shifting soil, one crack being wide enough I can see down over and inch, and all around the edges from surface to where it lays on the soil, I don't see anything that would indicate to me that this is something applied to the concrete pad or any type of coating, rather it is the same material all the way from top layer to the very bottom. All the same color. The impressions look just like Kool decking.
    Could this be stamped concrete to simulate Kool decking? I haven't ever pressure washed it because of what happened to my friend's decking. It surely could use a good pressure wash as I don't want to use chemicals and I have a pressure washer.
    Thanks, gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: Is My Decking Really Kool Decking?
    As old as your deck is and has no flaked areas along the edges, then its probably not kooldeck. I pressure wash mine in the beginning of the season. I use a rotating nozzle, makes a cone pattern. I use it at a 45deg. angle and don't get any closer than 18".
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by DaveNJ
    Whew.... I'm glad it isn't. But it has the same cooling affect as real Kool Decks I've been on. Our sun is intense so even Kool Decking can get pretty hot but not nearly as hot as other surfaces.
    So why go with Kool Deck when you can get stamped concrete that last a "lifetime"? BTW... mine is colored a light tan color all the way through. Except for the soil shifting issues it has withstood all kinds of abuse. I can't find even one spot where it has a blemish or staining except for the patch where a pipe under decking had to be repaired. Decking is very different than an older poured/brushed pathway that adjoins it on one side of pool between the pool decking and house. The pathway is concrete grey.
    I've had that pressure washer for about 10 years. I originally got it for the pool deck but was afraid to use it. My big deck is Trex and you are not supposed to pressure wash that. So..... I haven't even used it; I've loaned it out a few times though.
    Added pressure wash pool deck to bottom of very long "to do" list.
    gg=alice
