Thread: Cloudy water after shocking
    Jerry's Avatar
    Aug 2009
    New Orleans
    48
    I've repalced my pump and shocked the pool - keeping the chlorine level up and running the pump for 3 days.
    I still have cloudy water.
    What's the alternative to the clarifying chemicals?
    10,000 Gal. Inground Plaster Lap Pool
    Sand Filter
    New Orleans, LA
    Jul 2009
    London and France
    574
    Re: Cloudy water after shocking
    good filtration, if your sand is too clean it takes longer to filter the water clear so adding some DE (diatomaceous earth) may help as could some flocculent but patience can also work too
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    If you post a full set of test results, we can advise you better.
    Jerry's Avatar
    Aug 2009
    New Orleans
    48
    Quote Originally Posted by teapot
    Could be that I'm backwashing too frequently? We've had a lot of live oak flowers in the pool the last month...they break up into little crumbs and go right through the baskets.
    What's the rule of thumb for backwashing?
    Sand Filter
    New Orleans, LA
    11,969
    Quote Originally Posted by frustratedpoolmom
    If you have don't have a manual to refer to - it can be anywhere from a 6-10 rise in the PSI. Note the "clean" pressure for future reference.
    This could also be a chemistry issue, so if you can provide test results we can determine more.
