Results 1 to 13 of 13
Thread: Greetings from the Central Valley of Northern California
    Greetings!
    I wish I had found this board last year! What a resource and great community! As a way of introducing myself to the community, here's a bit of info about me and my pool:
    Last year I purchased a repossessed house that had been vacated and not maintained for over 8 months. The pool equipment had been either stolen or sold and the pool was left full of water over our very hot and long summer. (The water remained on during the vacancy so the automatic filler kept it topped off.) To get the loan for the house approved, I need to pay a local service to drain and clean my new gunite swamp and install a working pump and filter.
    The pool service used a pressure washer for the cleaning (no acid) and I picked up a used Hayward Northstar 3HP pump and a Purex Triton Mytilus FMY-150 filter. Although seriously mismatched with a pump too powerful for my pool and a filter too small, the combo did the job for my first year.
    Yesterday, I purchased and installed a Pentair Clean n Clear Plus 420 filter. At some point over the next couple years, I will upgrade the pump and get a heater for the spa. In preparation for the new filter, this past week I drained, cleaned (with a brush and water only) and refilled the pool. You'd think I would be ready for the season...except....
    I am not satisfied with the plaster surface. The neglect took its toll! There are numerous areas of discoloration and some areas where the plaster is pretty much gone and the bare gunite is exposed. Is this a problem beyond aesthetics, and what should I expect to pay for a good plaster resurfacing that will last 10 or more years?
    Mark
    Mark Stinson
    Woodland, CA
    IG 12,545g Gunite/Plaster with attached spa, Hayward Northstar 3HP pump, Pentair Clean & Clear Plus 420
    Alas, I have no heater for my spa (yet)! :-(
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Greetings from the Central Valley of Northern California
    Welcome Mark!
    (I can't advise your situation, I just wanted to say welcome )
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    We have had quite a few folks join up recently who have bought foreclosures with pools that have needed work. You're not alone, believe me.
    Because replastering jobs vary so widely in price depending on your location and local resources, you might be best advised to go ahead and start taking bids from local services. Get several and don't reveal your bids to other bidders in the process. Once you have a few, start a new thread on the forum here and ask others for feedback on what sounds good.
    Once again, welcome. By the way, you are going to love that filter!
    Guest
    Quote Originally Posted by 257WbyMag
    Welcome to TFP!
    Because replastering jobs vary so widely in price depending on your location and local resources, you might be best advised to go ahead and start taking bids from local services. Get several and don't reveal your bids to other bidders in the process. Once you have a few, start a new thread on the forum here and ask others for feedback on what sounds good. And, more importantly, check the BBB and Contractors State Licensing Board. I'd also highly recommend not using the low bidder!
    Once again, welcome. By the way, you are going to love that filter! Times 2
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by simicrintz
    Welcome to TFP!
    Thanks simicrintz! I knew that I had left something out. Absolutely check those backgrounds!
    Thanks for the welcome frustratedpoolmom! And thanks for the welcomes and advice, 257WbyMag and simicrintz.
    I already love the new filter. One noticeable difference in the system since installing the new filter is the increased suction and water flow. I am betting the old 150 sq. ft. filter was a serious bottleneck in the system, especially with such a small pool and a 3 HP pump.
    Tonight, it's back to the plumbing because I noticed a leak in one of the new pipe connections.
    Mark Stinson
    Woodland, CA
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Mark and welcome to the forum
    Sure hope you are taking some before and after pics that you plan to share with us?
    We just can't get too many pics!
    You're done SLAMing when:
    Rocklin, Ca
    467
    RPB,
    Welcome to TFP neighbor.
    I would recommend taking a drive down to Aqua Pools in Manteca. I know it's a bit of a drive but they have many many pools on display with lots of colors and types of pool surfaces. They will even let you take your shoes off and walk on them to feel them.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    Hi Butterfly! Thanks for the welcome! I think I have some before and after photos. I'll post some if I have them.
    Hi cobra46! I'll see if I can get down to Manteca to check out Aqua Pools in the next couple of weeks. I called Adams Pool Solutions earlier today to request a bid but haven't heard back from them yet. Any other suggestions for Sacramento area pool resurfacers?
    Mark Stinson
    Woodland, CA
    Rocklin, Ca
    467
    I think my neighbor across the street used Adams when he did his owner/builder pool and had some issues. I will verify when I see him again.
    I don't know of any others in our area.
    I called Adams last week for an estimate and had one scheduled for Friday...but after 3 calls back on Friday with changed appointments times we cancelled. I haven't heard back from them today. I'd very much like to hear about your neighbor's experience, cobra46.
    Mark
    Mark Stinson
    Woodland, CA
    Rocklin, Ca
    467
    Mark,
    I just spoke with my neighbor. He did use Adams to install his Pebble Tech as well as some other things. I asked about the trouble I recall that he had and said that it was Adams but it was because he asked them to do some extra things that were not within their normal capabilities. I then asked him if he would use Adams again to plaster a pool and he said yes.
    I hope that helps.
    Thanks, Cobra! I am debating whether to call back or not considering that I never heard from them after they canceling last week. I'm definitely going to try Aqua in Manteca.
    Mark
    Mark Stinson
    Woodland, CA
