Thread: Above Ground Pump on In Ground Pool?
    Jerry's Avatar
    Aug 2009
    New Orleans
    48
    My pump started making a louder whiniing noise this week....it was replaced in '06 with what may be an above ground pool pump.
    How can I tell if it's an above ground setup?...It's marked to fill with water before startring...is this a clue?
    After opening the basket it takes a few minutes to get pumping.
    If it is an above ground I think I'll not repair it and just get the proper pump.
    10,000 Gal. Inground Plaster Lap Pool
    Sand Filter
    New Orleans, LA
    Jerry's Avatar
    Aug 2009
    New Orleans
    48
    Re: Above Ground Pump on In Ground Pool?
    My pump is labled Hayward model sp2807x10, which on searching for it I find it described as an inground pool pump.
    Sand Filter
    New Orleans, LA
    A typical above ground pool pump will not startup properly if the pump is located above the surface of the pool water, regardless of how long you give it.
