Results 1 to 10 of 10
Thread: worms driving me crazy
    Sep 2009
    tennessee
    17
    Just spent 40 minutes dipping worms out of pool, every time we get a little rain one quarter inch last night resulted in 2" inches of worms in a normal sized leaf net. I stillhave some landscaping to do thinking of plant barrier with rocks as mulch outside fence against concrete any other ideas chemical or otherwise thanks.
    15k, ig ,vinyle ,kitbuilt, 1hp hayward, 24 hayward sand, 2-intex swg`s, manual cleaning, leslies k2006 test kit,14x28, fiberglass steps
    Butterfly's Avatar
    South Carolina
    10,045
    Re: worms driving me crazy
    We've had some members with that problem before. They'll probably be around to chime in.
    For now, try a google search (bottom left on page) for worms.
    Keep us posted!
    You're done SLAMing when:
    EEWWW....we get lots of worms also! Our pool was finished in the fall of 09 and the pump filter basket was always full of long yucky worms! I don't want to know how many are in the pool now...but I guess I will find out next week when it is opened! We also get worms all over the driveway after a rain. I have heard that if you have fertile soil you will have a lot of worms! Yuck!!!!!
    But how do you keep them out of the pool...I would love to know as well!!!!
    28,000 IG Free Form Gunite with quartz finish
    Pentair Quad DE filter, Intelliflo VS+SVRS
    Polaris 280, Sta-Rite 400K Heater-Propane
    Aug 2009
    North Central Texas
    1,358
    I haven't found any way to keep them out of the pool. I usually have the problem in March or April with heavy rains. No mater how long I run the cleaner some still get into the pump basket. They get stuck in the holes of the basket. The only way I clean them out is with vinyl or rubber exam gloves as even the strong pressure from hose won't dislodge them. We purchase boxes of exam gloves from Sam's or Costco (or DH brings them home from work) and use them for all kinds of jobs inside and out. DH even uses them when preparing meals to prevent raw meat contamination and for his sensitive skin preparing veggies and such and using cleaning products.
    BTW... I usually have some red worm colonies growing in worm bins recycling kitchen scraps (their castings, poop, is excellent potting soil amendment) and have no issues handling them, but dead, mushy earthworms, stuck in basket openings is not nearly as "nice" as the healthy read worms. The job of cleaning them from basket is one of the yuckiest jobs around here.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Feb 2008
    Denton, TX
    5,061
    We get them too when it rains hard. Once the water puddles in beds and lawn near the edge of the pool, they rise to the surface through the saturated soil and end up wherever the water flow takes them. You can add some drainage improvements to your beds and areas that typically collect storm water and it will help. But even then, some really heavy rains won't allow the drainage system to quite keep up and you will still have them to some extent.
    geekgranny is right though. Once those things get wound around a filter basket, you have to pick them out. They are sticky! We have skimmer socks in the skimmers so we don't get them there. Where I do get them is in the leaf catcher in my Baracuda hose. Yuck!
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by taintn
    Just spent 40 minutes dipping worms out of pool, every time we get a little rain one quarter inch last night resulted in 2" inches of worms in a normal sized leaf net. I still have some landscaping to do thinking of plant barrier with rocks as mulch outside fence against concrete any other ideas chemical or otherwise thanks.
    You really don't want to kill those earthworms. They keep the soil "tilled" and provide lots of good castings, poop, that enrich the soil. Many gardeners, who know the benefits of "earthworms" (any one who works in the soil whether ornamental or food) go to great lengths to protect them. Anything you do to the soil to kill them will also harm other beneficial organisms in your soil.
    You may want to run your pool cleaner for a longer period during times when they go swimming. If it is a suction cleaner, depending on your setup you can catch most of them using an in-line leaf canister or vacuum plate with skimmer sock.
    gg=alice
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    488
    I had problems with worms and also mole crickets, fire ants, june bugs, love bugs, 4 inch millipedes, spiders, slugs, and snails. The fire ants and mole crickets were the worst. The mole crickets were killing my grass and the fire ants would sometimes swarm and there would be hundreds maybe thousands on the pool surface. If someone happened to be in the pool they would get stung I finally had to start using an insecticide on the lawn and the that reduced the problem considerably. It didn't entirely eliminate all the bugs but it did reduce the numbers drastically.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    I put crushed lime stone around the pool. It seems that increases the pH of the soil and the worms don't like that so they turn around instead of up over the concrete and in to the pool!
    I use to get a pool full of worms with every rain, now I get less than 3 even with super heavy rains.
    32' x 15', 25k gallon gunite IG pool, California Quartz plaster in Tahoe color
    Pentair equip (Intelliflow VS+AU pump, DE filter, IC40 SWG)
    Spa wall removed to make "seating" area
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by falken
    Hey, there you go! Defeated by science.
    Sep 2009
    tennessee
    17
    thanks for the replies falken`s is the way i plan on going would rather have some other type of gravel perhaps pea gravel, not as sharp, but i definitely need to do smething.
