Thread: Solor heat question/advice
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    I am located in Texas where heating the pool is not a problem but I would like to stretch the season by 3 weeks or so beginning and end. I should also say that we have a lot of sun. These panels are only $225 and to me it seems worth it. I understand this will not be the most efficient not produce the most heat but it seems like it will help.
    So this might be hoaky but I am wondering if I could take these two panels and simply lay them on the pool deck concrete and power with a small pump on a timer during sunlight periods. I am thinking these will be out for only 3-4 weeks before the season begins and simply roll them up during the season and store them. Our poured deck around our built in gets so hot that at times you can't stand without something on your feet.
    Link
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Re: Solor heat question/advice
    Yes, that can work very well. You only need about 4 GPM per panel, or 8 GPM total, which is just under 500 GPH. It is not that difficult to install a diverter valve on your existing pump to tap off a little water flow. Or you can get some appropriate inexpensive submersible pump, though that could pose some safety risks if you were swimming while it was on.
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Thanks so much Jason. I can easily tap off of my pump as I already have a hose connector and adjustable valve. It would be easy to control.
    Polaris 280 robot
    Pool Calc user
