Thread: For those that switched to a SWG
    Mar 2010
    Spring, TX
    1,082
    What are your thoughts and opinions? From my understanding this almost eliminiates having to add any type of chlorine to your pool manually as the SWG does it all pretty much. So for those that switch from maybe adding it manually via bleach or liquid chlorine, did you see it as a good investment? Also I know it is hard to answer, but what is an average cost of doing this?
    Thanks
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Re: For those that switched to a SWG
    Our pool builder put in a pool for a friend with a SWG about 5 years ago. By the time they built mine about 3 years ago, they were seriously steering people away from them, but would install one for about $1200 extra. Now they won't even put one in even if you beg them (and they have given up sales as a result) after having to replace the flag stone for a customer (even after it was sealed).
    On the other hand, my next door neighbor has had one for about 8 years with no issues.
    Take all of that for what it's worth, but apparently at least in some circumstances, the salt can create issues with natural stone. I suspect though, that you will hear from lots of people happy with their conversion... I gather that the issues with the stone are not that common.
    20,500 gal gunite pool w/ PebbleTec and infloor cleaning system.
    Sta-Rite System 3 cartridge filter.
    Houston, TX
    Jul 2008
    Solon, Iowa
    170
    You are paying for convenience with a SWG. In a balanced pool once you get the SWG 'dialed in' and have learned how your pool behaves (chemistry-wise) you find that you don't have to test so much. Rarely do I have to toss in bleach or muriatic acid. The SWG's slow, sustained generation of free chlorine at the level your pool needs (depends on CYA, sun, cover, bathing load, organics in pool) is the key to the convenience factor. The cells/controllers require you to pony up several hundred dollars, which buys a lot of bleach. So the advantage is the convenience, unless you like empty bleach bottles.
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
    Jul 2007
    Brisbane, Australia
    874
    In my signature there is a link to calculator which can help you calculate the dollars.
    You will need some techy info from SWGs manual to use it.
    Id never go back to bleach, pucks, or tablets, or floaters unless I'm between dead cells (hasnt happened yet)
    It doesnt eliminate a trip to buy pool supplies- you still need to go to a store for "stuff"
    You still have to go to somewhere to buy acid, and will likely have to add a little every week, but you'll find that is pretty consistent- for me its about a quart a week. So a 4 pack lasts me 4 months, and I have a spare jug, so when I use up 4 I still have a month to go get a whole "shell" - Much easier than bleach.
    I still test regularly though, and find a SWG makes for a more stable pool all around.
    You also need to insure you have X amount of flow or they may not function at all- so if you are planning on running your fancy new variable speed pump at 100watts- it doesn't really work, and you definately now have a minimum speed at which things dont work.
    I have metal all around and havent seen any adverse effects to any of it for 3 years now. I haven't had any surface issues at all.
    As one poster said you are paying for convenience, - yeah and Im happy to make the payment.
    Dave
    20K Gallon Gunnite pool/900 Gallon in ground Spa/2HP WhisperflowSpa
    Pentair Master temp 400/Hayward Sand WZeobrite/Jandy RS-8 Aqualink/Jandy 2HP Epump
    12 - 4x10 Panels/Zodiac G3-T5 / BBB
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by CurtisT
    It seems that the issues depend on the type of stone that is used, whether it is sealed, whether there are summer rains diluting any splash-out, whether the temps and sun exposure are hot enough for enough salt buildup with splash-out and evaporation, etc. Texas seems to have more problems with this than most other areas, probably due to a combination of local stone characteristics and the hot dry weather. One can mitigate the stone issues by using harder stones or by sealing softer ones.
