Thread: My DE Filter Cleaning-Pictures on the inside
    Mar 2010
    Spring, TX
    1,082
    I decided to do this myself to save the money attached are pictures of it. I did not take pictures from start to finish.
    First set of pictures will be dirty and the second two will be cleaned.
    Enjoy
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Mar 2010
    Spring, TX
    1,082
    Re: My DE Filter Cleaning-Pictures on the inside
    Clean Ones
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Thanks for reminding me
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    This will be me next weekend.
    Plano, TX
    20,000 gallons Kidney Bean IG Plaster, Pentair Clean and Clear 530 Cartridge Filter
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by mynewpool
    Enjoy
    Good for you. Now that wasn't so hard was it? psssssssst Lie if you have to.
    Thanks so much for posting your pictures. It looks like your filter was in much better shape than the pictures I posted of one really caked up with DE and your pictures are another good illustration of how DE does get caked in so that an annual open and clean is needed for DE filters in most cases.
    Feels good to get that done, doesn't it? And a job well done.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by geekgranny
    Enjoy
    gg=alice
    I wish I would have taken pictures before even taking it apart. It was horrible.
