Results 1 to 8 of 8
Thread: New with testing questions
    Jul 2007
    Florida
    14
    Hello to all,
    I have been reading the site for a couple of days and decided I needed to ask for help. Here are the particulars.
    I am a new pool owner , I have always wanted a pool. I live in eastern Florida and my pool is IG, gunite with a gemcoat finish. My pool is 10,000 gallons and I have a Sta-Rite System 2, cartridge filter with an automatic chlorinator (it holds 3" tablets).
    We have had lots of rain this month, 9.5 inches. My pool was completed in the middle of May 2007. My water has looked beautiful and clear since they filled it. But I do have some lime scale on the wall of my sheer decent.
    Now to my problems and questions. After using test strips and not liking the results, I bought a Taylor testing kit. Since it was filled I have had trouble with my chlorine level and my CYA. My CYA is always high, 100-150, and we have tried emptying out water it goes right back to being high. My chlorine is either too high or too low. I am having trouble regulating it with the automatic chlorinator. I think that the chlorine tablets, which have stabilizer in them, is what's making my CYA constantly high.
    If anyone has any thoughts or comments I would greatly appreciate it.
    Thanks so much.
    klh66
    9K IG Gunite,1 hp. pump, Sta Rite 1-100 cartridge filter, auto chlorinator, sheer decent, built 2007.
    Yep, the chlorine tablets have CYA in them. In Florida, with it's long swim season, using chlorine tablets is going to cause problems with constantly high CYA levels. I recommend that you switch to bleach (or a SWG) as a chlorine source. Bleach doesn't add any CYA to your water.
    Jul 2007
    Florida
    14
    So do I stop using the tablets completely? How much chlorine am I supposed to use and how often?
    If you use bleach you need to test your chlorine level every day and add bleach to bring it back up to your target level, preferrably in the evening. How high you should target depends on your CYA level. My Pool Calculator can suggest FC levels you might want to use based on your CYA level.
    Welcome to TFP!
    you are getting some really good advice... Jason knows his stuff!
    Read the stickies (link in my sig) especially the first one. Click the triangle to read it! There is a ton of good info here.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Jul 2007
    Florida
    14
    Thanks for the info. I will go buy some bleach tonight.
    Do you know why there would be limescale on my sheer decent wall? Is it because of the CYA? I bought something to get rid of it, but am I fighting a losing battle Will I always have it no matter what I do?
    Jul 2007
    Florida
    14
    silly question but what is SWG?
    There are no silly questions. Asking questions is how we learn.
    A SWG is a salt water chlorine generator. You add about 3000 ppm of salt to the pool and then a special cell installed in the plumbing converts the salt into disinfecting chlorine (salt has chlorine in it). When the chlorine gets used up it turns back into salt. The unit runs whenever your pump is running so chlorine levels tend to stay more uniform that when using bleach. The salt does add a (usually small) corrosion risk and also makes the water feel much better on your skin. This saves a great deal of effort, no more manually adding chlorine.
