"floc" or "flocking" is a chemical which causes all of the stuff suspended in the water to fall to the bottom so you can vacuum it up. It can turn a murky pool clear overnight, but it doesn't always work, is a lot of effort, and is useless if you still have live algae.
It is normal for sequestrant to cloud up the water. Clouding caused by sequestrant normally clears up in two to four days. At the same time there is always a risk of getting algae while doing an AA treatment, which also clouds up the water. Not only is algae common, but it is extra difficult to fight algae without causing the stains to reappear. It can be a difficult situation.
I am not convinced that you have algae, though that is certainly a distinct possibility. I was hoping it was just calcium clouding, but that is ruled out now. The next step is to do an overnight FC loss test to find out if you have algae or not. If you don't have algae it might be time to try out either clarifier or floc.
