Thread: My bearings are starting to whine!
    Louisiana
    68
    I have a Doughboy Power Pak ll 1.5hp - 115v ac - 60hz - 3500rpm model# 0-1087-200.
    and a Doughboy sand filter i think it holds 225lbs of sand model# 1702-019
    This winter i got drunk while watching the BCS game and forgot to run the pump that night. When i got home i noticed a thin sheet of ice. So the next day at about noon everything had melted and i figured i would run it for a lil while. Well i guess there was still some ice somewhere in one of the lines. The pump started to whine a lil so i immediately shut it off. It still whines but it is running fine.
    The pump has got to be at least 5+ years old. I've owned the house for 3 years and i'm pretty shure they had the pool for quite a while judging by the wear on the skirting and the liner.
    I tried to figure out a spreadsheet someone posted on here but didnt put alot of effort to it. I have 10,000 gallon above ground and was wanting a pump that is quieter and more energy efficient. Obviously i need something that would work with my filter. Unless someone thinks it would be better to go ahed and replace that too and if so why.
    This is the one i was thinking of getting (Model E71-1 click)
    11,000g, AG, aqua rite salt, Dough Boy 1.5hp, well water with some metal in it, and 2 beautifull oak trees that dump a ton of leaves into the pool.
    I use TF Test Kit
    South Central NJ
    3,192
    Re: My bearings are starting to whine!
    SPECK makes a very dumbed down 1 HP 3 speed pump. The speeds are preset and fixed but it is quiet and very energy efficient. Its called the BADU EcoM3. You choose the desired speed by pressing 1 of 3 touch pad buttons.
    Scott
    Owner of - PoolGuyNJ LLC
    Louisiana
    68
    Yeah i talked to the pool store today and the suggested a spec. 1hp for $275.00 (Model E71-1 click) does anyone have have experience with one of these?
    Sorry pool guy but that pump is costs more than my pool is worth!
    I use TF Test Kit
    South Central NJ
    3,192
    http://store.poolcenter.com/shared/Stor ... 2Cart=True
    A few bucks less. Same store.
    Disclaimer: I don't know the store or have any financial dealings with either poolcenter.com or Speck.
    Scott
    Louisiana
    68
    that one is actually a lil more expensive but looks to be a better pump also.
    I use TF Test Kit
