Thread: A good ladder for inground Salt water pool?
    Mine has rust on the plastic steps, most likely from the bolts on the steps. I have metal issues and this is my suspect. Can someone recommend a good ladder for inground SWCG pools? I found on especially for SW through google and can't seem to re-find it.
    40'x20'x8' to 3', Vinyl IG with brick coping, built/opened 04/2006
    Hayward S244T Pro-series 300lb Sand Filter - vari-flo XL valve
    Goldline Controls Aquarite Turbo Cell SWG t-cell 15
    Hayward SP2607X10 Pump w/ Century Centurion .75HP motor (4th motor in 4 years all under warranty) Polaris 360
    Re: A good ladder for inground Salt water pool?
    Any ladder currently sold in the US should be fine, but occasionally less expensive bolts that can rust are substituted for the proper rust free bolts. Usually the simplest thing to do is to purchase stainless steel bolts of the correct size to replace your existing bolts.
    Yeah, I am going to have a good look at the bolts anyway. My brother in law is into sailing and they have issues with SS bolts anyways.
    I guess the follow up on my question is "Is there a place on the web that separates ladders especially for SWG pools. I found that on one of the major sites, but can't seem to re-find it. They had replacement steps and bolts in addition to coated SS ladders.
    Thank You
    Ft Lauderdale, Florida
    1,455
    There's nothing with a Salt System that would require you to have to look for a Salt Specific Ladder.
    Having said that, there are PVC coated ladders and rails. I'll see if I can find a link.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Nov 2009
    Indialantic, FL
    323
    I have no personal experience, but have heard a good review of the SR Smith "Sealed Steel" rails.
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    Thanks for the reply.
