Results 1 to 7 of 7
Thread: My Pool Build
    Dec 2009
    Central Massachusetts
    2,682
    My Pool Build
    I thought I'd post a few picts of before, during, and after my pool going in. My yard had a ~25 foot grade difference from the back of the house to the back of the property. I had to build almost 1000 sq ft of Versa Lok retaining walls to make it all work. The back retaining wall is 5 feet high at the highest point, had to be engineered, and the use of Geogrid cloth to tie it into the hill was needed to hold the wall. We hauled out over 400 yards of dirt and rock to get the grades correct and then use walls to make it all work.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Feb 2008
    Denton, TX
    5,061
    Re: My Pool Build
    Spectacular!! By the way, where do you live? Beautiful out there!
    Dec 2009
    2,682
    Re: My Pool Build
    Central Massachusetts. Not too far from Worcester.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    561
    Re: My Pool Build
    That is very nice. Alot involved in that build.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Dec 2009
    2,682
    Re: My Pool Build
    Believe it or not, the backhoe went in the ground to dig the footing for the back wall on August 13th, we were in the water September 1st. The rest was built by Columbus day. The following spring we did the deck and landscaping. So the hardscape and pool were done in about 2 months. This was done 2 and 3 years ago.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: My Pool Build
    Wow! That turned out absolutely beautiful
    You're done SLAMing when:
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: My Pool Build
    Nice build!
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
