Thread: Ocean stone liner and LED's
    Hey guys,
    It is about time for me to pick our new liner. We are going to get the Hayward color logic LED's to go with our new pool.
    My understanding is the lighter the liner the brighter the LED's will light.
    Right now we are looking at the Ocean stone bottom and I am wondering if this liner will be light enough.
    Here is a link of the Ocean Stone
    http://www.legacyeditionpools.com/index ... tegoryid=2
    Opinions?
    South Central NJ
    3,192
    Re: Ocean stone liner and LED's
    How big is the pool. LED powered lights are not as powerful as an incandescent. Pool shape and size may dictate two fixtures for best effects.
    The liner pattern you are going with is not that dark. That is a good thing.
    Scott
    Owner of - PoolGuyNJ LLC
    Thanks Scott,
    It is a 17 x 33 Grecian
    South Central NJ
    3,192
    Either a Hayward ColorLogics 4.0 or Pentair Intellibrite (better dispersion) will work. If the existing niche is for a Hayward, go that way. If it's a Pentair...
    If your pool was any larger, a single fixture would not be enough, especially with the darker colors like blue and purple.
    Scott
    Thanks again,
    We are going with the ColorLogics 4.0
    Since we are paying for the upgrade I just want to make sure this liner will allow us to view the changing colors ok.
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by dankfoot
    Thanks again,
    When my "Favorite Most Trusted Pool Guy" was out here working, last week, I asked him about this personal pool color/surface. He prefers the white plaster for many reasons including the light spreads around the pool better and with colored lights you get better visuals. He has three LEDs but I'm not sure what size they are. He has a kiddie pool that the infinity edge pours in to so maybe one is placed there.
    When I had my pool plastered in 1996 I was under the impressions that my water would be bluer with light blue plaster. I know this now from TFP, that as long as my water is balanced it should be blue with no hint of green. The only green cast I like in a pool is when greens that the light produces.
    My plaster is light blue to a medium blue (the plaster is darker when the pool is drained down a bit but plaster still wet) (it started out darker but is 14 years old) and one Color Splash LED replacement bulb, the big one, because I only have one niche. The pool is lighted enough for safety in the lighter LED colors. The niche is on the deep end wall. Of course I would prefer two lights and placed on the long side of the pool facing away from house but I had to work with what I had.
    With the lighter LED colors even the steps, off to the side, on shallow end are lit enough for safety as the lighter surface allows the light to reflect off the other close by walls.
    My pool is about 32' X 16'. All pictures taken after dogs had spent hours getting in and out of pool and swimming, dragging in loads of very fine, tee-nitsey silt. The silt is cleaned up off bottom but much still in suspension.
    gg-alice
    This is with the white LED - there is a lot of fine silt suspended in pool.
    I think this is the lightest blue - there is a lot of fine silt suspended in pool.
    This is with the white LED - there is even more very fine silt suspended in pool.
    Pool during day, over cast day, - lots of fine silt suspended in pool.
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
