Thread: Hayward Navigator Trouble
    I have had this Navigator forever, it came with the house. Last year we replaced almost all the parts (ebay was cheap). I am now having an issue with it that I cannot fix. I hate bringing it to leslie's because their parts are EXPENSIVE!
    Issue: Plus it in and turn it on, works fine for maybe 5-10 minutes, after awhile it does nto move. I pick it up and their is lots of suction but feet do not move. I have taken it apart a bunch of times and nothing is in the way and everything appears to be working.
    any suggestions? I have read troubleshooting on Haywards site and there is nothing there.
    12,000 Gallon
    Hayward 2HP Pump
    Solar Panel
    TF-100 Kit
    Built 2004, bought Dec 2007
    BBB All the Way
    South Central NJ
    3,192
    Re: Hayward Navigator Trouble
    What is your filter pressure? When did you last backwash? Are all the hoses in good shape?
    Scott
    Owner of - PoolGuyNJ LLC
    I have cartridge filters, they are brand new, the issue was happening before and after new cartridges. The hoses are just fine. I hook and manual vacuum and it works awesome.
    Let's say I am holding the navigator and it is working, pods are moving when it is in my hand. Now I put my hand in front of the scution to feel the suction a little and it stops moving.
    12,000 Gallon
    Hayward 2HP Pump
    Solar Panel
    TF-100 Kit
    BBB All the Way
    The Navigator requires a particular amount of suction to work properly. Too little or too much and it won't work. There is a gauge that normally comes with it that attaches to the suction line. With the pump on you adjust the suction untill the paddle is somewhere between the two black lines.
    Tustin, CA (Orange County)
    Curacao Quartz Finish (grey plaster with grey, black, blue & white quartz)
    29k gallon IG
    Pentair WhisperFlo Pump
    Pentair FNS Filter
    Hayward SwimPure T15 SWG
    Solved!
    It was the A-frame.
    12,000 Gallon
    Hayward 2HP Pump
    Solar Panel
    TF-100 Kit
    BBB All the Way
    tsunami's Avatar
    Sep 2008
    Oceanside, CA
    138
    Quote Originally Posted by nitz369
    Solved!
    It was the A-frame.
    What was wrong with the A-frame?
    40 X 26 Free Form Pool with attached 9 X 7 Spa raised 18" with 8 Jets and Spillover, and an Art Rock Waterfall/Grotto with accent rocks, 26,000 gallons
    Intelliflo VF-3050 for Pool, VS-3050 for Spa Jets, VS-3050 for Waterfall/Grotto, Quad DE 80, 400K BTU Mastertemp, Intellitouch i7+3 w/ iS10 10 Function Spa-Side Remote, Intellichlor IC40 Salt Chlorinator, Telephone Remote, 2 Intellibrites for Pool/ 1 for Spa, Solar Panels on 2 story Roof w/ 75% coverage
    Pebble Tec Tropical Breeze Tsunami's Pool Build
