Results 1 to 9 of 9
Thread: Plaster Pool Care
    Mar 2010
    17
    Plaster Pool Care
    I have been in the pool retail business for quite a while and I had a customer ask me a question the other that I wasnt quite sure how to answer as we do not have many ingrounds around here, and mine is fiberglass and concrete. He was telling me that he has a plaster pool with gunite underneath. It is indoor. He was getting what sounded to me like algae, but when he brushed the pool walls, white dust was coming up from the plaster. Is this a normal reaction? The pool is only a few years old, and he swears to me that his water is well in balance (because I suspected etching). Could anyone tell me a bit more about plaster pools?
    1965 Hybrid Pool, Swimquip U3 skimmer, Aqua slide n dive board and slide, Hayward Super pump, Hayward sand filter.
    Guest
    Re: Plaster Pool Care
    Sounds like it was painted to me.
    Mar 2010
    17
    He said it wasnt painted. I asked him that too.
    Guest
    Quote Originally Posted by Leslieslsa
    Yeah, I've heard that response too
    Any chance you can get out to see it? Plaster doesn't behave that way (it is more granular). If your description is accurate (based on what he told you!) it sure sounds like a painted pool to me.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Welcome to the forum!
    Ask your customer to bring in a sample of his water for testing... presuming your work space allows you to test water samples for pH, FC, CC, CH, TA and CYA. The test results may give you a better idea. If the pH is way out of range or the levels of calcium and/or alkalinity are too low, perhaps it is the plaster degrading. Do you know what the customer uses to chlorinate the pool?
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Plaster sheds white dust for a week or two when it is brand new. Paint commonly sheds white dust when it is old. Dead algae can sometimes be white and dust like, but it doesn't normally adhere to the walls of the pool (and usually isn't white).
    Mar 2010
    17
    He is using mostly potassium based non chlorine shock, because he has a mineral sanitizer. (nature 2) I told him he had to use some chlorinated shock, if he wanted to get rid of his algae, so I gave him some cal hypo. When i talked to him, he hadnt used chlorine in months.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Any chance he has a DE filter which might be bypassing some DE?
    Luv& Luk
    -Ted
    Mar 2010
    17
    Well I didnt think to ask him that, but in my experience it typically sinks to the bottom rather than on the sides.
