Thread: My pump pressure guage
    Sep 2009
    Spring, TX
    258
    I am not sure how old my equipment is, but it all seems to be working. When I got back from my christmas break around end of December, I did a good backwash. Dropped the pressure down to around 10. Every since then the pressure guage has stayed around 10-11, but recently has gotten up to around 12-13 and does not go any higher as of yesterday. There is plenty of pressure as when I vacuum it pulls up stuff with no issues. The outlets in the pool are putting out a lot of pressure and the pool looks clean. So is there a way to test the guage or should I not worry about it? I have vacuumed a few times this weekend and there was a lot of dirt and the presure has moved up to around the 12-13 which I am sure has to due with the small particles that were not caught by the filter basket. Before I backwashed it was a little over 20, maybe around 22-23. If you want me to post pictures of my equipment I can as they are in another thread.
    Thanks.
    Re: My pump pressure guage
    Everything you describe sounds like your pressure gauge is working correctly. They most often break by getting stuck in a single location, which obviously isn't happening.
    Sep 2009
    Spring, TX
    258
    It just seems like a long time between backwashing. I guess that could have to do with the pool not really being used for swimming.
    Feb 2008
    Denton, TX
    5,061
    It is also possible that some debris has found its way into the sensor mechanism and has dampened the sensitivity of the gauge. Happened once to me. I unscrewed it, rinsed it out real good, and replaced it. Worked fine after that.
