Thread: phpbb website
    Sep 2009
    Spring, TX
    258
    phpbb website
    I see this is ran under phpbb software. I used to run a phpbb and over on the phpbb website there is a lot of information on things you can do to the site. I noticed you said you can not get the post to redirect right back to the post. I used to run a board and I could get it to redirect right back.
    Re: phpbb website
    Certainly there is a mod I could apply to give you the behavior you desire. However, there are already so many mods and private customizations applied to the site that it took me 30+ hours to apply the last phpBB update and then get all of the mods and customizations working again. If some requested feature requires more than a simple adjustment of an existing configuration setting, there needs to be a substantial level of interest before I will consider applying yet another mod.
    If you know of some existing phpBB configuration setting that will give you the behavior you desire, by all means point it out to me.
    Sep 2009
    Spring, TX
    258
    Re: phpbb website
    Ok thanks for the explanation.
    Sep 2009
    Spring, TX
    258
    Re: phpbb website
    Here you go. Says time is under 1 minute.
    http://www.phpbb.com/mods/db/index.php? ... ib_id=2871
