Results 1 to 9 of 9
Thread: cheap sequesterant
    mikergibson's Avatar
    Jun 2007
    Mt. Vernon, Illinois
    34
    cheap sequesterant
    All things being equal, what's everyone's choice for a cheap metal sequestrant?
    I use it often as our water has a ton of iron in it. It would be great to
    find a place online to get it on the cheap.
    There seems to be common household equivalants to just about everything,
    I guess that's no so with metal sequestrants?
    My Pool:
    12K gal Fiberglass. Pentair DE Filter, Aqua Logic SWG, GoldLine Controls, Kreepy Krauley pool cleaner, MiniMax 250 Heater, Pentair FiberWorks Fiber optic lighting, Pentair 1 1/2HP Pump, a new shiny TF100 test kit, a clear pool and 3 happy kids
    yeah it is not adding any and letting your pool turn red. you want cheap you get cheap. Just go to the pool store and buy some. If you don't have enough money to afford a pool you probably shouldn't have one. I see too many people let their houses end up in foreclosure simply because they can't afford the pool that goes with it.
    Take this for what it's worth, as it's my N=1 experience and it may or may not be a good idea, I don't know.
    Back when clorox added the "rust out" chemical to their bleach, I didn't catch it and added it to my pool.
    The next day I noticed a pile of brown particulate about 8' out from my return line. It looked EXACTLY like what I got in the same place the year we had a heavy iron issue and used ferra tabs.
    This was discussed at poolforum, and I don't recall the exact outcome, but it seemed to precipitate metals for easy removal in my pool. What metals they were, I don't know, as I had used copper algaecide the year prior a few years back from that we had iron. Probably a combination.
    I have had great luck with the hth Brand Metal Control from Walmart, the pool store had a metal sesquesterant that was not HEDP based, so I did not buy it because I had seen that advised against, so I checked out the hth brand, it's less than 10 dollars for a quart I think, and it works about a week, then I put another quart, I only have 6000 gallons. I could probably get by with less, but I do not want to take chances.
    I don't think it makes someone a terrible cheapskate, after learning about Baking Soda especially to wonder if maybe there is something else we commonly use that is cheaper and can be used for metal control.
    Fort Wayne IG Vinyl 18 x 36 (22,000 G)
    3/4 hp Pentair Pump
    Sand Filter
    Polaris 280 w/ booster pump
    No heater yet...solar cover
    Mount Airy, NC
    Jun 2007
    34
    Poolio, maybe you should switch to decaf
    Often those with money are constantly being frugal, those without money spend like there's no
    tomorrow wanting to portray something that they are not. You don't always get what you pay for
    'nuff said.
    My simple question was whether or not there was an alternative to pool store chemicals.
    I have been using jacks pink but I order it off of the internet for 6-7 bucks cheaper than the
    local pool store has it.
    I will try the hth brand, what's the difference b/w hedp based or non hedp?
    thanks for the tip, as always I learn something new every visit
    My Pool:
    Mar 2007
    Sunny, Humid Central Florida
    30
    Quote Originally Posted by poolio
    I don't think there's anything wrong with seeking advice from others. That's why we're all on this board; trying to learn from others' experience. I can afford my pool, but I'm always looking for solutions that work and if I save a little money that's a bonus.
    Chris
    Guest
    Ace Hardware sells their house brand O-Ace-Sis Metal Out Plus for about $10/quart in my area. The stuff is actually twice as concentrated as most of the other brands out there since the normal dose is a pint per 10k gallons while most of the others dose at a quart per 10k gallons. I have been using it lately and it seems to work just as well as Jack's Blue stuff or Proteam Metal Magic. They are all HEDP based sequesterants.
    mbar's Avatar
    Ashland PA
    257
    Thanks for the tip Waterbear
    16x33 fiberglass pool sand filter
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I have been using Metal Myte from Menards at about $9 qt. It is 4oz per 10K gals. Works great, watch for sales at the end of the season when they clear out the summer stuff and its all dirt cheap and this stuff will last a long time as long as you don't let it freeze I think.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
