Results 1 to 7 of 7
Thread: Hilarious newbie question
    Jan 2010
    Sacramento
    10
    Pool is about 8 weeks old, 15,000gal, Peble sheen, run pump about 14hours a day - water clear (looks good) temp at 50, Cleaned filters to get rid of startup gunk about two weeks ago.
    Tested my pool using the strip - got somthing like this.
    TH - 100
    TC 1
    FC 10
    BR 20
    PH 6.8
    TA 120
    Stabilizer 0
    Then used the test kit -
    on the Chlorine test add 5 drops #1 - get blood orange color Way high on the measuring kit chart Chart
    Do ph test - right at 6.8 - 7.4
    Do total Alkalinity test - add one drop #4 and 2 drops #5 - turns clear blue add solution #3 - get to 30 drops - no change at all - so I guess alkalinity is off the chart high
    So I plan to add Muriatic acid and hope the sun comes out and reduces the chlorine.
    Am I even close on this?
    Thanks
    14,500 Gallon, Pebble Sheen, Spa – Jandy inteliflow, Jandy filter, Jandy Heater (Gas) Haywood Color logic 4.5 x 3 - Novice but spending freely
    Guest
    Re: Hilarious newbie question
    Why no CYA?
    Pebble pools tend to require more acid than plaster pools. Is there a reason that you are waiting for the sun to come out to start adding it?
    The chlorine will drop by itself (unless you are producing it or adding it some way!).
    Why are you running your pump for so long??
    Jan 2010
    Sacramento
    10
    Hi Bruce,
    So I should add Cyanuric acid not Muratic?
    The pool was really very hazy and I have just run it from 6PM through 8am to try and bring clarity - guess I can step it down to 8 or so now. We have had a lot of rain (4 inches) for SAC.
    Not adding Chlorine so will just wait for this to disipate
    David
    Jan 2010
    Sacramento
    10
    One more piece of data - Have a SWG - but was advised not to add salt and turn it on until the water gets to 60.
    so there is no salt in the pool plan to add in about 4-6 weeks as we get warmer
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by rellumd
    Hello, welcome to the forum
    • Unless this pool is using some sort of acid start-up procedure (is it?) I wouldn't lower the pH any more with MA.
      The test results you reported seem a little off somehow (mostly the pH range 6.8 - 7.4) What test kit do you use?
      Not sure about a couple of other items: Total Alkalinity -- is it 120? If so, that's fine.
      If the Calcium Hardness (CH) or Total Hardness TH is really only about 100 ppm at some point soon you'll want to boost it.
    It's OK not have to salt in your pool until the water temperature warms up enough so you're ready to start the SWG. CYA (Cyanuric acid) is different than MA (Muratic acid) and used for different purposes. Just make sure you have chlorine in the pool until you have an opportunity to add CYA (it helps to maintain your chlorine levels throughout the day). Add MA Muriatic acid when the pH goes up higher than recommended levels.
    Please check out ABCs of Chemistry and other articles in Pool School. It'll give you a good sense of how to approach the pool.
    Congrats on the new pool!
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Jan 2010
    Sacramento
    10
    No acid startup procedure
    I will add some CYA
    Will also look at the CH/TH level and boost that
    Yes I believe from the test that TH is 120
    Thanks for the help as I work through this - I know it is not really Hilarious - But is probably fairly basic
    Thanks
    David
    I suggest you get a top quality test kit, the TF 100 from TFTestKits.net is excellent and the Taylor K-2006 is also a good choice. Accurate test results make a huge difference and will save you way more than the cost of the test kit over time.
