Thread: deicer question
    deicer question
    can potasium chloride deicer be used instead of calcium chloride deicer. Im in mammoth right now and all the stores have a potasium chloride deicer. I was hoping to stock up for the drive back to the OC.
    18,900 Stonescapes Tahoe Blue xtra black, 8 jet Spa, Pentair inteliflo VS , Pentair FNS 60 DE, Inteliclor40, Pentair 400,000 Mastertemp heater, 3 spillovers powered by a Pentair 1 HP whisperflo pump, The pool Cleaner, 2 Intellibright color changing lights and 400 sq ft. of Heliocol roof mounted solar.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: deicer question
    If your intent was to increase the Calcium Hardness (CH) in your pool, then no, you cannot use potassium chloride for that purpose. It is the "calcium" in calcium chloride that increases CH; potassium won't do that.
    If your intent was to deice, then yes, potassium chloride can be used but recognize that it is similar to regular salt (sodium chloride) except it is not as harsh on plants, but note that like regular salt, it will not work well at lower temperatures below around 15F. Calcium chloride works well even at very low temperatures.
    Re: deicer question
    Thanks-
    I thought it was a silly question but you never know.
