Hello:
Are there LED conversion kits available for AmerQuartz and Astralpool 21626 underwater lights? At least on flashlights LED´s seem to outperform halogen bulbs. Has somebody experience, maybe building it´s own conversion?
Hello:
Hayward Pump SP2805X7 Hayward Sandfilter S210T used by switching a manual threeway valve for either a IG overflow pool with 3700 Gal. or a second IG skimmerpool with 5550 Gal., both tiled with and white cement/beachsand rim, the upper pool with sculptured white cement/beachsand waterfall.
I assume you have the flat type bulb. Is it 120, 12, 24 volt? Does it plug into the socket with pins or screw in. There are more and more LED replacement bulbs coming out on the market now. I did a quick search but couldn't find a specific LED bulb for your light. I would think any LED bulb, at the right voltage, right pins or screw, shallow enough, and bright enough could be used. I've been replacing a lot of my outdoor low voltage halogens with LEDs. There are many more selections, though, in lower wattage bulbs.
One thing that could be done, maybe, is to replace just the receptacle for the bulb if you can't locate a specific bulb that meets your requirements.
If you could post your voltage, wattage, and how the bulb plugs or screw in that would help a lot.
BTW.... I have a brand new LED color changing Spa Light, 120 volt, 30 ft cord (whole light fixture and bulb) that I need to sell for a steal. I ordered the wrong light for my pool and waited too long to return it. I don't want to put it in my spa as we don't want that much light. I ended up buying a ColorSplash, color changing LED, standard screw base, to put into my old standard light bucket. I don't know what wattage the Spa light is it is but I can check.
gg=alice
1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
I see on this page http://www.archiexpo.com/prod/pentai...019-27827.html an AmerQuartz (Pentair) that would probably take some of the LED replacement bulbs for pools that are on the market now. If you have this AmerQuartz you wouldn't have to do any conversion, I don't think. You just replace the bulb with one that is right voltage.
gg=alice
Hello:
The bulbs (2 of them per Amerquartz) are the 12 Volt, 2 pin Type T-3 GY 6.35 which are available up to 100 watts. Any direct LED replacement for this type?
Regarding your light: I am in the Philippines and we have 220 volts.
The Intellibrite fixtures come in a 12 volt version. There is no bulb.
Scott
Owner of - PoolGuyNJ LLC
This is how you can really save on electricity cost: Replace your old outdated halogen or whatever bulbs with LED´s in 12 Volt. They use only 10 Watts each. My first try failed, they overheated. Mounting them on the original fixtures let them run too hot, they produce lots of heat. You really need to mount them on the biggest aluminum sheet metal that fits into your light housing. See attached pics for the AmerQuartz with 2 LEDs and for the Astralpool 21626 with only one LED. Do not buy the Astralpool 21626, their plasic lenses always crack after a while on the rims and let water in - garbage product!
There are more powerful LEDs but they require a higher Voltage, meaning changing your transformers or installing converters.
