Thread: Stains in pool plaster
    May 2009
    San Carlos, Sonora, Mexico
    21
    After hurricane Jimena we had between 26 and 50 inches of rain here in San Carlos, Sonora, Mexico. Because of this we had no electricity for about a week. We were gone and the person who maintained our pool that normally uses a SWG for chlorine threw 3 inch chlorine tablets into the bottom of the pool to prevent the pool water from going bad. Needless to say, this bleached the bottom of the pool which is plaster with Hidrazzo goulstrem blue. We now have 6 inch diameter spots that look like mold. The pool maintenance person has brushed them which did nothing. What is the best way to fix this? Do we need to completely drain the pool?
    14,000 gallon in ground plaster pool with Hidrazzo goulstrem blue finish with infinity edge and spillover from spa, Pentair challenger 1 1/2 HP filter pump, 2 HP Pentair challenger spa jet pump, Hayward 30" sand filter, Pentair IC40 SWG, Raypack 5100 heat pump, Jandy Aqualink PS8 controls, Kreepy Krauly
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Stains in pool plaster
    Quote Originally Posted by da2434890
    I don't know enough about this type of finish to offer guidance but suggest that you browse through some of the threads on this site where it's discussed.
    http://www.google.com/search?q=Hydrazzo ... eepool.com
    The chlorine tablets may have effected a mini-acid wash on those areas, modifying the color and texture of the surface.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Guest
    You might try and contact these guys and see if they can offer some help: www.aquavations.com
    May 2009
    21
    Thanks for your reply to contact Aquavations. First I realized the correct spelling so that I could figure out what product I have. Aquavations sounds very helpful and is having me send pictures and it might be possible to fix the issue by not draining the pool.
    Guest
    Happy to help! Good luck!
