Thread: Test Results
    Sep 2009
    Spring, TX
    258
    Test Results
    Water Temp-50 degrees
    Results
    pH-8.2(Cause by aeration and possibly rain)
    FC-.5
    CC-0
    TC-.5
    TA-210
    CH-170
    CYA-20
    I have been trying to raise my CYA by using chlorine pucks but it seems to be dropping. I assume this is to a large pH level combine with a large TA level. I need to go turn down the vents so they no longer aerate.
    What do I need to tackle right now?
    Thanks.
    Re: Test Results
    With the water fairly cold, and assuming there aren't any problems you didn't mention, I would drop the PH down to around 7.4, add a little chlorine, and leave it at that for now. In the spring you can work on getting CH up, TA down, and CYA up.
    Chlorine tablets (trichlor) will add CYA, but only quite slowly (especially in cold water, where they dissolve more slowly than usual). The CYA test isn't precise enough to measure small changes in the CYA level, and tends to read lower than actual when done with cold water.
    Sep 2009
    Spring, TX
    258
    Re: Test Results
    Should I stop using the pucks since the water is so cold?
    Re: Test Results
    You can keep using the pucks for now if you want, it is just that they won't raise the CYA level very much. As long as you are able to run the pump, it is a good idea to keep a little chlorine in the water over the winter, and the pucks are a good way to do that, especially given that your CYA is low and PH seems to get high.
    Sep 2009
    Spring, TX
    258
    Re: Test Results
    I am trying to use them up since I will be using bleach for chlorine instead. If I am using the pucks, do I still need to add bleach or will the pucks work just fine for now?
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Test Results
    Quote Originally Posted by laurandavid09
    At 50° F. you're probably OK no matter what you decide to do but if this were my pool after adjusting pH with muriatic acid, I'd get the FC up to 5-10% of CYA ... the pucks wouldn't be able to add anything quickly enough to suit me so I'd add liquid chlorine to boost FC from .5 ppm to somewhere between 1 and 2 ppm minimum. Also think this is one case where it wouldn't do any harm to leave the pucks in -- when your water gets to be 65 degrees and the CYA starts getting close to 40-45 ppm, watch out... er, rather, pull the pucks out!
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
