Thread: Should I add water to the pool?
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Our pump pot busted on the filter and of course made the water level drop to below the skimmer. The pool cover has about 3-4 in of frozen ice on it. I have 2 4x8 air pillows in there and can tell they are squished down a little and I can also tell that it is putting some strain on the cover. Should I add some water to bring it back up or just leave it be until spring? In any case I will have to drop the water level to replace the pump pot. Just don't want to ruin the new cover or risk messing up the liner.
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    South Central NJ
    3,192
    Re: Should I add water to the pool?
    Since the water is below the skimmer, remove the return fitting in the pool and plug it. Put a short Gizmo in the skimmer. As long as you keep the water level to just below the skimmer lip and drain the water of the cover, it'll be fine. Then you can drain the equipment and lines and fix the pump when you are ready to.
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2008
    Evans, GA
    323
    Thanks Scott! T plugged the skimmer and I have the filter draining since yesterday.. I guess I should have done this a while back but since we don't get as cold as we have this year. I just normally run the filter and pump on cold nights. But instead I was more worried in keeping my palms from freezing to death! Just have to wait for the ice to melt, so I can start the siphon. Its frozen solid on there!
    *~ Laura ~*
    TF-100 Test Kit
