Thread: HELP! Need a replacement part on my pump
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Well, the cold did it. It broke the lip where the clear lid screws onto the housing of the pump. I am not sure what its called, The pot, I am assuming? How can I just replace that part? Looks like I might have to buy a new pump all together
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: HELP! Need a replacement part on my pump
    It should be possible to replace the part that's broken. Check out part #11 on either of these sites:
    http://www.poolplaza.com/C-Dynamo-Parts.html
    http://www.poolcenter.com/parts_pumps_pacfab_dynamo.htm
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Mar 2008
    Evans, GA
    323
    Quote Originally Posted by polyvue
    Thank you so much!! Just what I was looking for. It shouldn't be to hard to replace right? I mean a caveman can do it? or a cavewoman?? lol
    *~ Laura ~*
    TF-100 Test Kit
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    It's very easy to replace. The only tricky part is that it threads in, so if the pump is mounted to a base it will need to be removed so that you have enough clearance underneath it to turn the basket.
