Results 1 to 7 of 7
Thread: Recommended Pliar Size for Pool Use
    Sort of a basic question but can someone recommend a good size of waterpump pliars for pool union fittings? My Lowes didn't carry anything large enough when i closed last Fall. The pool guy i hired had a pair large enough, but i am going to DIY opening this spring.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: Recommended Pliar Size for Pool Use
    Ah the old Channel-Locks. Channellock makes a 16 inch pair which has a jaw capacity of 4-1/2 inches, which should handle it. They call them tounge-and-groove pliers, and the 16 inch is a model 460. I'm surprised that you didn't find them at Lowes - their item number is 97470.
    If that's not big enough, they have a 20-1/4 inch model (5-1/2 jaw capacity) which is a model 480. I don't think that Lowes carries that one, so you may need to find a tool dealer or online source if you need to go that big.
    Nov 2009
    Indialantic, FL
    323
    I use a set (2) of strap wrenches I bought from Sears for a little over ten bucks IIRC. Every place that sells tools should have one, it's just a rubber strap thing attached on one end to a plastic handle, strap goes around the union, and slipped back into the plastic handle. As you attempt to turn, the strap sort of "self-tightens" to grip and then loosen the union. As a bonus, they don't tear up the plastic union either like a Channel-Lock pliers can do - if you're all thumbs like I am sometimes.
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    South Central NJ
    3,192
    Channel Lock's Oil Filter wrench works well also. Very large jaws, thin enough to tighten a Hayward threaded flush union to a Super Pump, and it fits in a 15" tool box.
    Scott
    Owner of - PoolGuyNJ LLC
    Jan 2009
    Cupertino, CA
    1,966
    I remember my dad had what he called a "monkey wrench" flat jaws, not like the grooved jaws of a pipe wrench (which are intended to grip on a galvanized pipe or fitting). I have never been able to find one, though, the closest was a monster crescent wrench but not really what I wanted. Finally broke down and got the channel-lok.
    --paulr
    BBB "Intermediate Swimmer"
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Like these?
    Jan 2009
    Cupertino, CA
    1,966
    Yes, we had both of those. As I recall, dad called the top one a monkey wrench, the bottom one a Ford wrench--saying it was the only tool required to do any necessary maintenance on your, hmm, Model T or maybe Model A, memory has faded.
    So, given the condition, I should be cruising yard sales instead of hardware stores?
    --paulr
