Results 1 to 6 of 6
Thread: Calcium hardness of 450ppm in hot tub?
  1. Back To Top    #1
    Join Date
    Nov 2018
    Location
    Mankato, MN
    Posts
    9
    My calcium hardness is pretty high, should I mix it 25% hard water to 75% soft t9 get me at about 100ppm?
  2. Back To Top    #2
    Mod Squad Texas Splash's Avatar
    Join Date
    Jun 2014
    Location
    South-Central Texas, Marion/San Antonio
    Posts
    17,807
    Re: Calcium hardness of 450ppm in hot tub?
    A CH of 450 is starting to be a bit much. In pools we might manage it (compensate) with a lower pH. In a hot tub however, it may simply be easier to swap the water. Perhaps time to do an Ahh-Some cleaning and start fresh? Curious though …. is your local MN water that hard, or is the CH increase due to constant use of Cal-Hypo? Can you also confirm for us how you are testing the CH? Which test kit are you using?
    Pat (a.k.a. Texas Splash) ~ My Pool: Viking Fiberglass; 17,888 Gal; Waterway Supreme 2-sp/2-hp pump; Hayward Ctg filter; TF-100 w/ Speed Stir
    Vital Links: POOL SCHOOL, RECOMMENDED LEVELS, RECOMMENDED CHEMICALS, Poolmath Calculator, SLAM, Chlorine/CYA CHART.
    If you enjoyed your TFP experience, please consider donating to Support TFP!
  3. Back To Top    #3
    Join Date
    Nov 2018
    Location
    Mankato, MN
    Posts
    9
    That is the hardness right out of the tap. My city water is from a deep limestone aquifer, after all the water softener was invented in Minnesota.
    I am am using a Taylor 2006 test kit, plus local water company’s show our water hardness at 30 grains
  4. Back To Top    #4
    Join Date
    Jun 2014
    Location
    Posts
    17,807
    Yikes. That water is southwest territory-worthy. Okay, then two things to consider ..... replace with some soft water is you are able. Also watch the pH to ensure it doesn't spike to high which if it does would tend to add to the CH's ability to cause scale over time. With the 2006 kit, do you also have the magnetic speedstir? If not, you might consider getting one from TFTeskits.net. The speedstir has been known to actually show a slightly lower CH result due to its efficient mixing.
  5. Back To Top    #5
    Join Date
    Nov 2018
    Location
    Mankato, MN
    Posts
    9
    The good news is I have yet to fill my tub, so the world is my oyster. I do use a magnetic stirrer, and that would make sense why my reading is a bit lower than the conversion of grains per gallon to ppm as supplied by our city.
    so the question is, how hard is optimum?
  6. Back To Top    #6
    Join Date
    Jun 2014
    Location
    Posts
    17,807
    Always best to refer to our TFP Pool School - Recommended Levels page. Use the non-salt column. You might also find the following link helpful: How do I use Chlorine in my Spa (or pool)?). Hope that helps.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
