Results 1 to 14 of 14
Thread: When in Spa mode
  1. Back To Top    #1
    Join Date
    Jul 2008
    Location
    Houston Texas
    Posts
    14
    When in Spa mode
    We just finished having our pool resurfaced and replaced all of our pool and spa coping and stone surrounding our elevated spa. We are still in the process of getting our water balanced using the pool company to perform the start up. Our spa pours into our pool when in pool mode, when we switched it to spa mode this weekend to cycle it the pump will not get a full prime... We have tried letting air out of the filter release but that doesn't work. We can switch back to pool mode and the pump self primes just fine and the spill over from spa starts back up. Any suggestions as to what the problem could be? They will be back out again today and we intend to tell them about this problem but I thought I would try to get ahead of it by getting some input from you guys.
    16,000 gal gunite pool with white plaster finish flagstone coping elevated spa with spillover and flagstone wrap around Hayward Aqua Logic PS-8 SWG 400,00 BTU natural gas heater Natural moss rock waterfall and full side rock wall with 2 trickles Polaris 280 cleaner(Are about to have pool refinished with Stonescapes Aqua White with travertine coping and travertine split-face ledgestone spa surround installed Nov 2007 will be refinished Nov 2018)
  2. Back To Top    #2
    ajw22's Avatar
    Join Date
    Jul 2013
    Location
    Northern NJ
    Posts
    2,339
    Re: When in Spa mode
    Sounds like there is a problem with your spa suction line. Could be at the valve by the pool equipment or in the spa.
    -Allen
    IG 20x50 35,000 gal Cayman Lagoon Hydrazoo plaster w/ spa & waterfall, Pentair Intellichlor SWG, Pentair Mastertemp 400BTU Nat Gas Heater, Pentair FNS Plus 60 DE Filter, Polaris 380 cleaner, Meyco solid winter cover, TF100 Test Kit, Built in 2000 & replastered in 2017
  3. Back To Top    #3
    Join Date
    Jul 2008
    Location
    Houston Texas
    Posts
    14
    Are you referring the the electronic valve or the check valve? We replaced the check valve as the flapper wasn't closing all the way when off causing the spa to drain slowly into the pool. The electronic valve appear to be moving all the way. Could it be that the lever on the top looks like has moved fully when in fact the insides are not?
  4. Back To Top    #4
    Mod Squad Jimrahbe's Avatar
    Join Date
    Jul 2014
    Location
    Bedford, TX
    Posts
    9,850
    mom,
    If the intake valve was not moving or even only moving half way, you should still get plenty of "pool" water to prime your pump.
    For the pump not to prime only in the spa mode seems to me to be more of a plugged spa drain line. I suspect they plugged the line on purpose when plastering and failed to remove the plug, or plugged it accidently during the replastering and just did not realize it..
    Jim R.
    Finished in 2015 - 17K Gal, IG, 20' x 25' Almost Rectangular Pool, Pebble finish, three rockport water falls. Pentair Equipment: EasyTouch 4, IC40 SWG, 3 HP VS Pump, CCP520 Cartridge Filter.
    TF100 with SpeedStir and SampleSizer, ColorQ Pro 7, Dolphin Premier Robot Cleaner, added Screen Logic 2, added small 3 person Caldera Spa.
  5. Back To Top    #5
    Join Date
    Jul 2008
    Location
    Houston Texas
    Posts
    14
    That is what we were wondering. I saw them pull a rag out of one drain hole but didn't notice on the second one.
  6. Back To Top    #6
    KDpoolguy's Avatar
    Join Date
    Mar 2017
    Location
    Palm Desert, CA
    Posts
    263
    I concur, have them remove the spa drain cover and see if they plugged it with crumpled plastic or a rag. Could still be in there.
    Our lines were slathered over with the new plaster/pebble coat and had all matter of semi-clogged returns in the spa. They weren’t too careful with this and even our Autofill line was almost 80% clogged, requiring some arterial surgery to ream out the hardened plaster.
    Let’s hope it’s that.
    Kevin has a: 11000 gal. IG Gunite Caribbean Blue mini-pebble, 7’x5’ pool shelf, Free-form 32’x14’x6’ pool +1000 gal. IG Spillover Spa. Chlorine. Built: 1987, Reno: 2017 . Features: Hayward Tristar SP3200VSP pump, Raypak 266k NG Elec heater, Pentair C&C+ cartridge filter, 1Hp Starite spa pump, Venturi Jets, In Floor Cleaner: A&A valve w/ Turboclean refit w/A&A QC1 heads, Auto-fill leveler, Bulbwizard LED lights.
  7. Back To Top    #7
    Join Date
    Jul 2008
    Location
    Houston Texas
    Posts
    14
    Spoke with the PB last night about the issue. He said he had never heard of that before... hmmmm Anyway, the construction manager is suppose to come out today to take a look at it. Fingers crossed for an easy "rag still in the hole" fix.
  8. Back To Top    #8
    ajw22's Avatar
    Join Date
    Jul 2013
    Location
    Northern NJ
    Posts
    2,339
    Seems like “I have never heard that before” is the standard response they teach in PB school.
    -Allen
  9. Back To Top    #9
    Join Date
    Jul 2008
    Location
    Houston Texas
    Posts
    14
    Ok so the guy came and checked the spa today and said that the washers in our valve are what is causing the air leak not allowing the pump to fully prime. He showed hubby by putting his finger between the auto thingy and the valve and had a few drops of water on his finger when the valve was switching. He also stated that he could hear "air" when it was in full spa mode. How do we find out what washers/rubber seals we need to get in order to fix that? Here is a picture of it. Any help would be great. I think that they are Jandy. Do I just need to google Jandy valve washers? Sorry for the sideways picture I guess i needed to rotate my phone.
    Attached Images Attached Images
  10. Back To Top    #10
    Join Date
    Nov 2015
    Location
    Carrollton tx
    Posts
    489
    Doug - Purchased 1/2016, 1995 house with 16x31 ft, ~23000 gallon Gunite pool w 11x7 spa, 3 Pentair VS pumps, a boost pump for polaris 3900 and a Badu® Jet super-sport swim jet pump, 1.5 hp blower, a CL460 Cartridge filter. TF-100 test kit. Aquapure 1400 SWG, iAqualink - Lots to learn. New Aquabright, Jandy LEDs, CMP LED Sheers.
  11. Back To Top    #11
    Join Date
    Jul 2008
    Location
    Houston Texas
    Posts
    14
    Great! Thank you for your help.
  12. Back To Top    #12
    In the Industry
    Pool Clown's Avatar
    Join Date
    Sep 2008
    Location
    Silicon Valley, CA
    Posts
    1,797
    You probably don't need the diverter, but for that price, it wouldn't hurt to keep one on hand.
    https://www.amazon.com/Jandy-Valve-R...alve+oring+kit
    Yes, that is a generic (Super-Pro), just as good,
    Factory Warranty Station for:
    Jandy/Zodiac, Pentair, Sta-Rite, Raypak (Rheem, Rudd), Polaris,
    and Paramount pool cleaning systems.
  13. Back To Top    #13
    Join Date
    Jul 2008
    Location
    Houston Texas
    Posts
    14
    Quote Originally Posted by Pool Clown View Post
    K. thank you Pool Clown. We ordered the other one that same night. We looked at the one you just sent and wondered if it was all good since it was generic. Now that we know we will save that link in case one of the other valves needs patching up. Will be here on monday I think. We were wondering if we should go ahead and change the diverter at the same time since it will be open or if we should store it.
  14. Back To Top    #14
    In the Industry
    Pool Clown's Avatar
    Join Date
    Sep 2008
    Location
    Silicon Valley, CA
    Posts
    1,797
    Since Jandy came out with the NeverLube diverters, I haven't changed many of them, so i would just keep it for a spare.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
