Hello all
Owning a pool is a new experience for me, but I've been bumbling through this site and learning a lot. For the last 5 weeks I've been attempting to achieve the levels on the TFP calculator. I tested once a week, and it took a fair amount of CYA to bring the level up.
I have a few questions below and I would appreciate some advice before I make a mess of things coming into summer But first here is some relevant info:
I don't have a pool cover, the pool receives full sun and summer is about to start.
The SWG manual states pH 7.2-7.4, TA 90-150, CYA 40-65, Salt 4,500-5,500, chlorine 1.5-2.0.
1. I slowly raised the CYA, but now it has shot up to 100. Should I run the SWG at a higher level until I achieve 5 to 7 FC, or should I try and lower the CYA level?
2. The TFP website recommends a higher CYA and FC level than my SWG. Which should I follow? I'm currently using the TFP goal settings in the calculator.
3. I am losing about 1.5" to 2" of level every week. Mean daily evaporation rates here for November were 7.6mm so it seems to make sense. I managed to lower my TA to 110 but it climbed back up, perhaps from filling approx 1,500L of tap water at 125ppm every week. What should I do here? My SWG manual states up to 150ppm is acceptable, but should I be concerned about this?
4. What will this high evaporation generally do to my other levels over summer? If recommended I will buy a pool cover, but I'm afraid the water will get pretty warm.
5. I've been maintaining 7.6 pH, should I lower this for the SWG?
6. My salt level seems high from what I have seen, but it's within the range of the SWG so I assume it's OK?
7. I changed the pump gasket after it sprung a leak. No water leaks out, but the system seems to take in air when I shut the pump off and drain itself rapidly. Air bubbles rise into the SWG and it drains completely. When I start it up, the pump primes but the return jets blow out air bubbles for a long time. Should I be attempting to get the plumbing air tight or is this normal?
8. Perth has high wind, so the pool quickly fills with leaves, pollen and bugs. I always have the floor cleaner attached so the skimmer isn't functioning, so I was considering a surface skimmer that attaches to a return jet. Are these effective?
Thanks!
14-Oct | Today | Tap Water | |
FC | 1 | 4 | - |
CC | 0.5 | <0.5 | - |
CYA | <30 (off scale) | 100 | - |
pH | 7.8 | 7.6 | 7.6 |
TA | 125 | 110 | 125 |
CH | 225 | - | 100 |
Salt | 5,600 | 4,800 | - |
Temp | 20 | 24 | - |
Thanks!
