Thread: Donít understand how to use a vacuum head
    SunLover18's Avatar
    Jul 2018
    Fort Worth Tx
    44
    I ďget itĒ in theory. Before I go invest $ on a hose, I donít know how to hook it up to skimmer and I donít know how it will pick up these big heavy leaves there are so many..
    In Ground 45,000 Gallon Pool, 3-10 feet deep. DE Filter: Hayward D. E. ProGrid Pool Filter 48 SF DE4820 Pump: Hayward RS1500, 1.5 HP 1.33SF 2.00 THP Polaris Booster pump PB4-60 Polaris 3900 Sport Pool Cleaner ​Re plastered in 2004 and new tile
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: Donít understand how to use a vacuum head
    You should be netting out the bulk of the leaves.
    Most skimmer's accept skimmer plates. They go above the skimmer basket and the suction vac hose goes into them. That way the leaves are caught in the skimmer basket. Or you can get a leaf catcher that installs along the hose and also captures the leaves.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    Jul 2014
    Hope Mills, NC
    636
    You will be suprised just how much suction will be in the vac head. The skimmer doesnt really look like its pulling water in, but it is, now take all that water area of the skimmer and concentrate it into the small hose.
    Mine can suck up a leave from a foot away.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    SunLover18's Avatar
    Jul 2018
    Fort Worth Tx
    44
    Ok can someone send me a link of pics of what I need to buy? I didn’t know about the skimmer plate. And the leaves go in there?
    23000 gal gunite plaster pool Jacuzzi Magnumforce pump and Hayward 325 Cartridge filter Maryland
    The answer to 90% of the questions are "Add more Bleach" "get a good test kit"
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,162
    quite a few videos on YouTube on how to hook it up.
    Divin Dave,
