Re: FAS-DPD kit and Slam questions
Hello Joanne!
Here in the states we tend to do things a bit different for public-type pools because of specific regulations. Not sure if you have those issues there. So please keep that in mind as I provide you with some possible actions to take. Also, since you have an indoor pool, they also have some unique issues to consider. So I'll try to answer your questions with those things in mind:
1 - Yes, colorless, then record your FC (or CC) right away. If you let the solution sit it will begin to change to pink again. Disregard that.
2 - Your math is correct (4.0). Sounds like you have some water issues and the
SLAM Process is probably a good decision.
To perform a
SLAM Process, we take our current CYA and go to the
[FC/CYA][/FC/CYA] to find the corresponding FC SLAM/Shock level. In your case, you show next to no CYA. For our indoor pools, we typically advise about 20 ppm of CYA. The CYA can be lower because indoor pools typically receive no sunlight, so you don't need much CYA (stabilizer) like an outdoor pool. Also note that a pool with little to no CYA means the available free chlorine (FC) will be quite harsh on swimmers, swimsuits, etc. So you might consider increasing the CYA to "20". From there, you can increase the FC to "10" which is an adequate SLAM/Shock level to perform that
SLAM Process.
Make sure before increasing the FC to that higher (10) level, you first add the stabilizer AND adjust your pH down to about 7.2. From there, you would maintain the SLAM level (10) until you pass all 3
SLAM Process criteria. Make sure to read all the details of the
SLAM Process page to ensure success.
Joanne, if you have any concerns about performing a SLAM for your indoor pool based on local restrictions or the fact it is used as a swim school, you might need to discuss your options with local authorities. I hope that helps get you going. Let us know if you have any other questions.
