Guys, I understand you need CYA, just not at the astronomic levels I have in my pool right now, which is clearly the result of using tabs. I'm thinking of draining the pool, partially, in Jan/Feb to reestablish the chemistry and install all of that Pentair paraphernalia. If the CYA is at a good level then what's wrong with running the IntelliChem? The nice thing about it is that it reports the pH and ORP - which if the CYA is in check, which I will manually still check, is reasonably accurate, right?
