Nd: docs wiring 2sp 2HP Jandy Stealth to Aqualink
taekwondodo
419
Will have the pump tomorrow, also have the 2SP switch for the RS-6 Aqualink coming as well. The on-line jandy doc for this config is poor (non-existent) at best.
Hoping there's a better diagram coming with the pump. Saw this thread http://www.troublefreepool.com/dual-speed-wiring-question-t14547.html?hilit=wiring two speed, and assuming that the wiring is similar.
Another assumption with the Aqualink: The RS-6 will control the pump such that when AUX 0 (F. Pump) is "on", the pump is in "full speed" and when AUX 2 is "on", the pump will be on 1/2 speed - but nothing in the doc confirms this. Currently, AUX 1 controls the cleaner JVA.
If you've done this before, help will be appreciated.
- Jeff
Yes, the two speed relay will eat up one of the aux.s. Do you have an empty aux to put the jva on? If not, maybe combine seperated lights to open one up. Also, there is the "extra aux" to use if you don't have a solar heater.
