Hi friends at TFP,
I'm new to the forum, but already benefited a lot from the pool school materials and the pool math calculator. Thanks to you who created those resources.
I have a 13,000 gal salt water pool. I started maintaining it myself end of August and everything worked out well. I use the Taylor K-2006 test kit for FC, pH, TA and CYA, and the AquaCheck test strips for testing salt level. So far, all I needed to do was adjusting the chlorinator level for proper FC and adding Muriatic Acid from time to time to lower pH.
Recently, I noticed the salt level dropped to about 2690 (reading of 5.8 on the test strip), probably due to a lot of rains. So I grabbed a 40 lb bag of "Diamond Crystal, Solar Naturals Water Softener Salt Crystals" for $5.93. It's advertised as "Made naturally and contains up to 99.6% pure salt". The pool math showed that the 40 lb solar salt can raise the salt level to above 3000.
I added the whole bag yesterday morning at the deep end of the pool, near the main drain. The crystals disappeared in a few hours. The pump had been running for at least 12 hours. I tested the salt level yesterday afternoon, and got the same result of 2690. I thought maybe the salt hadn't dissolved evenly across the pool, so I tested again today. Again, I got the exact same reading of 2690 (5.8).
I don't know why the salt level didn't raise even a little bit. So I'm hesitant to add more bags before I find out the cause.
I tested salt level a few times and it wasn't always 2690. So I don't think it's the test method. Here are my test results in the past couple of months:
8/30 4110
9/15 3770
10/4 2930
10/14 2690
10/17 2690
10/18 2690
Any ideas? Please let me know. Thank you in advance.
8/30 4110
9/15 3770
10/4 2930
10/14 2690
10/17 2690
10/18 2690
