- May 23, 2015
- 24,381
- Plaster
- Pentair Intellichlor IC-60
Only Pentair would call a power supply a "surge board"...
Of course these are the same people that sent someone out to replace the flow switch.. I assume because the failure had the word "salt" in it...
Jim R.
If the board has a thermistor on it (can’t tell from the picture) then it would not be totally wrong to call it a “surge board” as the electrochemical cell will have a very large in-rush of current when it switches on. If that current surge wasn’t limited in some way, the excess heat and stress on the wiring and components would eventually fry something. So it’s not totally wrong but it could simply be called the “converter board” and be left at that.....
