Results 1 to 9 of 9
Thread: Pros and cons of draining 50,000 gal in ground pool for winter?
  1. Back To Top    #1
    Join Date
    Jun 2018
    Location
    Michigan
    Posts
    10
  2. Back To Top    #2
    HiddenRiver's Avatar
    Join Date
    Jun 2017
    Location
    East Coventry, PA
    Posts
    318
    Re: Pros and cons of draining 50,000 gal in ground pool for winter?
    Quote Originally Posted by Nicole9993 View Post
    Hi Nicoleómy humble opinion and observation
    Prosóthe pool water wonít turn green over the winter
    óthe new water you refill it with wonít have high CYA if you need fresh water to lower CYA
    Consó it could cost a lot, if you have municipal water that is metered to refill
    ó-depending on the chemistry of the new water you might have to add a bunch of chemicals to balance it properly and this could cost some money
    ó-if you use a well, it could burn out your pump (thatís a lot of water!) when refilling
    ó-if there is an issue with the integrity of your pool excavation soils not having water in the pool will not provide the structure to hold up the walls or push down on the bottom of the pool. If there is ground water pushing ďupĒ on the pool bottom it could move or crack the pool bottom
    ó-it could be more dangerous than if water was in the pool if someone should fall through the pool cover, as your pool must be deep!
    Thatís what I can think of at the moment. I hope it helps! I am sure others will chime in-Good luckí
    40,400 inground gunnite, max depth 10-ft with 1.5 hp single speed Pentair, DE filter, well water, only one skimmer working, TAYLOR TK-2006 TEST KIT COMP CHLORINE FAS-DPD, Chester County, PA--OLD pool, but a beauty.
  3. Back To Top    #3
    Catanzaro's Avatar
    Join Date
    Jul 2014
    Location
    Monmouth County, New Jersey
    Posts
    3,204
    Nicole:
    For starters, please add your signature.
    It is extremely difficult to answer this question without knowing your pool, type of cover, dimensions of the pool, your surroundings, the cost of water, type of structure, your past experience, etc., and why you are asking this question.
    I have a friend with a 90,000 gallon pool. The safety cover cost $13,000. After a few years, it ripped and was deemed useless. Since then, the pool is closed for the season & not covered. In the spring, the pool is drained and refilled after a thorough cleaning. As you can see, a liner pool could never be accomplished this way, but a concrete/gunite pool can. Please advise. Thanks!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
  4. Back To Top    #4
    Join Date
    Jun 2018
    Location
    Michigan
    Posts
    10
    Please advise on how to add my signature.
    Thanks!
    Thank you for the information.
    We have a couple issues at hand.
    1. My elephant cover guy fell through.
    2. I need to do tile and cement work in spring.
    3. Not too worried about people falling in
    4. Just tarp it till next year? Need to close or drain this week
  5. Back To Top    #5
    Catanzaro's Avatar
    Join Date
    Jul 2014
    Location
    Posts
    3,204
    Nicole:
    How to add your signature:
    Pool School - Read This BEFORE You Post
    Are you 100% positive your pool is 50,000 gallons? It does not appear that large from the picture. How did you derive at the size?
    I would just close it, tarp it and call it a day. If you leave open or empty, the amount of leaves in the pool may be too much. Even if you emptied it, there will be rain water and leaves entering from the winds all winter. Then come spring, you can dump the water and make the necessary improvements.
  6. Back To Top    #6
    Join Date
    Jun 2018
    Location
    Michigan
    Posts
    10
    I will add my signature thank you so much I appreciate your help. I think itís 45,000. It is 12 or 13 feet deep and itís a kidney bean shape. Iím definitely getting on board with just tarping it.
    Thanks again
  7. Back To Top    #7
    PoolGate's Avatar
    Join Date
    Jun 2017
    Location
    Damascus, MD
    Posts
    2,365
    Hmm.... From that pic I doubt you are even close to 50k gallons. Looks like under 20k to me. Why do you think it is 50k?
    29k Gallon Free Form Gunite Pool, 3 floor returns, 2 wall returns, 1 vacuum pressure port, 2 skimmers, Main drain, Jandy 2.7HP VSP, Jandy JXI400N Gas Heater, Jandy CV340 Cartridge Filter, FusionSoft 1400 SWG, 2 Watercolors LED, iAqualink with PDA, Sheer Waterfall, Rock Waterfall, 9' Deep End w/Diving Board, SunDeck, Polaris 9650iQ, TF-100 - Pool Build - 2017 - Google Photos
  8. Back To Top    #8
    I agree that it doesn't look anywhere near 45,000 gallons. I seriously doubt that it's 12 or 13 feet deep. It's probably less than 9 feet.
    Have you actually measured the length, width and depth?
    In any case, leaving a pool drained risks floating the pool or damaging the plaster.
    If the plaster heats and cools differently from the concrete, it can cause delamination due to stress induced by expansion and contraction.
    Support the site
    Trouble Free Pool is a free resource. The people who answer questions are volunteers. If you find the site to be a good resource, please consider making a donation to help support the site. Thanks.
  9. Back To Top    #9
    Join Date
    Jun 2017
    Location
    East Coventry, PA
    Posts
    318
    Thanks again
    Hi Nicole! My pool is 10 feet at the deepest point and gradually gets shallower to about 3.5 feet. Our pool is 24 feet by 40 feet and that comes to a little over 40,000 gallons. Pool Math will help you calculate the volume of the pool. People tell me that our pool is bigger than most.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
