Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Big Green Egg or Similar question
  1. Back To Top    #1
    Join Date
    Jun 2016
    Location
    NE/Pa
    Posts
    1,693
    I figured I would post this here for all you guys who are always posting up ur smoked foods on the other thread.
    I am getting a green egg. it is going to be sitting on a piece of 3 inch limestone. here is my question and I was running this by Cliff before.
    If I use the nest it will make my grate height 42 inches off the ground due to the finished height of my limestone being 21 inches. If I don't use the nest I will be sitting at 39 inches.
    1. do you all think 42 inches is too high vs 39 inches?
    2. Since I'm sitting on solid limestone do i even need the nest? there is no airflow under the egg so i figured i could skip the nest and sit right on my stone.
    opinions. . .
    i'm also not set on the green egg yet. i just hovered to it cause it's the one i see the most in my area. . .
    jim
    TFP - Come for advice, stay for the education, leave with knowledge -
    35x23/20 free form gunite 3.5-6 feet water. 20,000 gallons. 2 skim, 2 ret, floor ret, floor return. 2 inch solid. suction cleaning line. 1.5 inch solid. super blue diamond brite. NPT Gemstone Blue 2x2 with custom Disney Mickey markers. pentair equipment. master temp 300,000 BTU. de 60. inteliflo 3.0 VS. swg ic40. 3 globrite LED's. ET 4/SL. tf-100/ salt kit
  2. Back To Top    #2
    JoyfulNoise's Avatar
    Join Date
    May 2015
    Location
    Tucson, AZ
    Posts
    14,225
    Re: Big Green Egg or Similar question
    From a fellow Big Green Egg owner let me say - WOOOOOOHOOOOOO!!!!!
    My Egg is built into my BBQ deck. You done need the nest BUT the air inlet door is on the bottom of the Egg so access to that door with a good amount of room around it is essential.
    Can you post a picture of your layout?
    And you ABSOLUTELY NEED the ceramic plate-setter for indirect smoking ...
    Matt
    16k IG PebbleTec pool, 650gal spa, spillway and waterfall, 3HP IntelliFlo VS / 1.5HP WhisperFlo, Pentair QuadDE-100 filter, IC40 SWCG, MasterTemp 400k BTU/hr NG heater, KreepyKrauly suction-side cleaner Dolphin S300i robot, EasyTouch controls, city water, K-1001, K-2006 and K-1766 test kits, Mannitol test for borates
  3. Back To Top    #3
    Join Date
    Jun 2016
    Location
    NE/Pa
    Posts
    1,693
    IMG_1079 by Jim, on Flickr
    Untitled by Jim, on Flickr
    hey mat these r 2 unfinished pics. u can see i have all brick around. there is a hood over the area too. picture a 3 inch thick piece of limestone in that opening and pavers on the floor. so the egg will be 42 inches off the pavers. with no metal nest under the egg i will be at 39.5 inches.
    i have seen pics on the net without anything under them. i figure i would be good cause it's all fireproof surfaces. the vent will have breathign room cause it's totally open to the air.
    what do you think?
    jim
    ps the ceramic plat e is that egg sitter thing u put inside right? bear with me. i never had anything like this so this is all knew for me. we cook alot. i have only used an electric smoker before.
  4. Back To Top    #4
    Join Date
    May 2015
    Location
    Tucson, AZ
    Posts
    14,225
    They changed the name of it and call it the convEGGtor
    convEGGtor¬ģ | Big Green Egg
    You need it to act as a fire wall between the hot coals and the grate. It forces all the hot air and smoke to convect around the food. It’s an absolute must-have for smoking at low temp.
    Your setup is AWESOME (love the overhead vent...super smart way to go!). You do not need the nest. The EGG weighs a TON and when you set it into place it will not move. I’ve seen setups where people suspend them in the cutout but that’s just a waste in my opinion. Honestly I wish my setup were more like yours as mine is built into the counter too and so I have to contort myself a bit to get to the lower air vent. Your setup is perfect.
    One other thing to get will be one of those fancy WiFi controlled air fans to automate your smoker temp. I don’t have one but they are helpful at low temps.
    Caution - the outside of the Egg can get blazing hot and I have easily gotten my internal Egg temp over 750F. Little fingers can get burned easily somif you expect to have kids around then you might want to put brackets on the brick work for a baby gate or some other barrier to keep kids and animals out.
    Matt
  5. Back To Top    #5
    Join Date
    Jun 2016
    Location
    NE/Pa
    Posts
    1,693
    Matt,
    thanks for the complements! I didn’t have a ton of room to work with so trying to fit a lot in a little area.
    Ok so im sitting on the stone. Nice. I’m only 5’3” so the lower the better I really thought I messed up cause I’m not buying the egg till next spring.
    This is all knew to me. I prob have a ton to learn.
    So besides the egg egg plate thing. What else do I need.
    I have been looking at the blower system. Didn’t want to mention it cause I figured all u guys here who are pretty seasoned smokers would be like that’s cheating. Lol
    im thinking I like the pit boss one vs the bbq guru one cause the fan is variable vs high low.
    So anything else that is handy?
    O went back and forth on the outdoor vent but my buddy said I should really do it cause of having a wood ceiling and I’m going to close in the other side for winter and fall to still be able to use the building. I’m going to have roll down awning material made to block off the 3 front openings to keep the heat in so we can still be out there and cook. I won’t have the bath or water by then but no big deal.
  6. Back To Top    #6
    Join Date
    May 2015
    Location
    Tucson, AZ
    Posts
    14,225
    Jim, some pics for you to consider -
    From left to right -
    Black circle - Grille Armor gloves...a MUST-HAVE. They are a Nomex/Kevlar blended glove that resists extreme heat (as long as they ar not wet). I can literally pickup a red hot grill grate and not get burned. About $26 on Amazon.
    Green circle - ConvEGGtor lifter. It basically allows you to pull out the ceramic convEGGtor without using your hands on it. Very handy to have. Amazon also, forgot the price.
    Red circle - grille grate lifter....another handy device for lifting out a hot grate without touching it. Amazon also (can you tell where I shop )
    Yellow circle - Official BGE cover. Get one, and you’ll look like a BOSS!!
    The tape measure is for your awareness - see how the Egg opens? You need at least 30” from the front of the Egg (mine is a large Egg) to the back of the lid when opened all the way. So when you place your Egg, make sure you have the margins right.
    NOTE - do you see the black metal band that straps the Egg top to the Egg bottom with the mechanical spring hinge in the back? It MUST BE INSTALLED ONLY ONE WAY...in other words there’s a top and bottom. The idiot that built my grille deck installed it backwards and, when he opened up the Egg to show me what an “awesome” job he did, he bent the bracket. I did not know it at the time but I was having trouble closing the egg properly and it would creak when opening. I called in an outside company that does BBQ islands, stoves, fireplaces, etc, and he looked it at it and laughed. He told the guy that installed it did it all wrong So he swapped it around for me and fixed what got bent but my Egg has always had about an 1/8” offset between the top lid and bottom. It seals fine but a new strap bracket would have cost me ~ $150 at the time and so I decided to live with what I have. It’s been 5+ years and it’s still working fine but man was I ticked at the time (same moron also ordered an LP grill instead of an NG grill and so I had to fix that mess as well....). Anyway, long story short - READ the installation instructions carefully.
    Another shot -
    And this is a must if it doesn’t come with the Egg -
    That top chimney adjustable vent is a must have for getting the smoke levels right. Also, everyone here (besides me I think) has one of those WiFi BBQ controllers...so it’s most definitely NOT cheating.
    Matt
  7. Back To Top    #7
    Join Date
    Jun 2018
    Location
    Long Beach, CA
    Posts
    7
    Forget the platesetter / conveggtor and go straight for the Adjustable Rig. It's really what should come with the BGE from the factory. I have the R&B Combo with the added Extender. It's expensive, but a game changer.
    Also, check out the Egg Heads at the EggHeadForum. I've learned a ton on there.
  8. Back To Top    #8
    Join Date
    Jan 2018
    Location
    Joshua, TX
    Posts
    61
    First off love the setup. Hope to do my own one day. Not sure if it'll fit with your cutout but I'm looking at the primo xl ceramic grill. I'm sure the eggs are nice and well accepted in the BBQ community. I personally just like the oval design more and they're made in America
    Big Green Egg vs. Primo Ceramic Grill Comparison : BBQ Guys
    20K gal, IG, Salt, Kidney w/spa, plaster, beach entrance, 3'-7' deep. Pentair Equipment: EasyTouch 8, IC40, Pentair VS Pump 011056, Triton II TR100 SF, old Legend cleaner.
    Taylor K2006C, SpeedStir, K1766 Salt test
  9. Back To Top    #9
    Join Date
    Aug 2018
    Location
    LI, NY
    Posts
    5
    It is suggested you have an air gap below the Egg to help keep isolate it, otherwise your stone base would act as a heat sink.
  10. Back To Top    #10
    Join Date
    May 2015
    Location
    Tucson, AZ
    Posts
    14,225
    Quote Originally Posted by SPenfold View Post
    Mine actually sits on a concrete base inside the BBQ deck. Itís direct contact and I still can get my Egg to go anywhere from 200F on the low end to +750F on the high end. So Iím not sure that the bottom contact matters all that much. One could put some fire brick or glass fiber insulation under it but I donít think it really matters that much. Thatís been my experience with it.
    Matt
  11. Back To Top    #11
    Join Date
    Aug 2018
    Location
    LI, NY
    Posts
    5
    From the manufacturer website : "THE EGG IS DESIGNED TO BE USED IN A METAL NEST OR WITH A METAL TABLE NEST, PROVIDING AN AIR GAP BELOW THE EGG –"
  12. Back To Top    #12
    Join Date
    May 2015
    Location
    Tucson, AZ
    Posts
    14,225
    From the manufacturer website : "THE EGG IS DESIGNED TO BE USED IN A METAL NEST OR WITH A METAL TABLE NEST, PROVIDING AN AIR GAP BELOW THE EGG Ė"
    I understand that. But I think the purpose of the admonition is to avoid burns, not loss of heat. The ceramic gets hot, thereís no doubt about that. The nest would create an air break which would keep the smoker from transferring heat to another structure which can cause burns. However, Jimís design is brick with a slab of limestone underneath it. There will be some heat transfer but nothing worse than what one finds in a brick fireplace. So, in my opinion and with 5 seasons worth of experience running my Egg, I can say that not having the nest has not caused me any negative consequences.
    Take it for what itís worth....
    Matt
  13. Back To Top    #13
    Join Date
    Jun 2016
    Location
    NE/Pa
    Posts
    1,693
    Matt,
    thanks man. I got a great Xmas list now! Lol
    i don’t see the pics though?
    so I don’t know what u are talking about with the hinge. I gave myself 30 inches to the brick for the large. Actually 31 so I’m good then I assume.
    Thanks for all this. I can’t wait! The local place I’m buying it from is a authorized dealer and they deliver so hopefully they know but at least I’ll have a pic forcreference.
    Thanks!
    jim
    Quote Originally Posted by JoyfulNoise View Post
    Attachment 87517
    Another shot -
    Attachment 87518
    Attachment 87519
    Thanks. I’m going to check that out tonight when I’m on a regualar screen vs a phone.
    I appreciate it!
    Quote Originally Posted by MooneyFWD View Post
    I was looking at that one last night. I was also looking at some full stainless steel one that was like 3 grand then I found ones that r hand laid tile. Komodo kamado something like that. Those r 4 grand so I decided to step away from the screen and stick woth the green egg since I can buy it local and physically see it. I felt like I was calling down the rabbit hole. Lol
    i also just bought a natural gas built in Weber summit grill. This project is getting out of hand. Lol
    Quote Originally Posted by Too_Tall View Post
  14. Back To Top    #14
    Join Date
    May 2015
    Location
    Tucson, AZ
    Posts
    14,225
    Jim,
    Not sure why the pictures came as attachments and not inline images but I’ll try to fix the post later.
    Matt
  15. Back To Top    #15
    Join Date
    Jun 2016
    Location
    NE/Pa
    Posts
    1,693
    here is what i'm dealing with for the surface. i would think any heat intakes on would just dissipate through the stone pretty much. even when i build a fire and it's like 700 plus degrees the limestone ledge of my 1 fireplace doesn't get hot. i can sit on it. my kids can place their hands on it.
    here r my cabinets my buddy's shop made for me. we swapped some work for work. they r sapele (part of the mahogany family). wicked dense and great for outdoor use. my ceiling is going to be this so we figured lets make some other stuff vs buying stainless. so i'm finishing up sealing them. no stain. looks better natural. it's so humid here that they sat in my garage for a week and swelled up like made so this morning we had to take the 1 door apart and plane down the braces that held them flat. obviously that didn't work. lol it's good now. we had to rip down the other 2 doors a 1/16" so they r good now so i was touching up a few spots. just need some hardware now. thought i would share since we were talking outdoor setups.
    sink access door. 36" inch cabinet for storage and a garbage pull out.
    jim
  16. Back To Top    #16
    Join Date
    Jun 2016
    Location
    NE/Pa
    Posts
    1,693
    that's pretty cool. so it gives u the same indirect heat as the big green egg version? so the main thing with this is to give u multiple levels for more cook space pretty much?
    jim
    Jim,
    no problem man. i'm just cleaning the pool. well actually wall-e is cleaning and i'm surfing for big green egg toys. lol
  17. Back To Top    #17
    Join Date
    Jun 2016
    Location
    NE/Pa
    Posts
    1,693
    Thanks Matt. I see them now. Very cool setup! I have all that stuff marked on amazon already. Lol. I really think I’m going to do the new pit boss temp control bs the bbq guru one. That variable speed can just makes better sense.
    Thanks for all the help. U have me wanting to go out and buy my egg now to use now but winter is coming and I got a ton of other stuff to do till then.
    Next year hopefully i can I can post on the smoking thread. I’m sure my first few pics will be of burnt over cooked messes compared to all u guys. I always lurk over there. So many good eats!
  18. Back To Top    #18
    Join Date
    Aug 2017
    Location
    West Palm Beach/Florida
    Posts
    87
    9C4D0767-D57A-4E79-8292-73E6AD76561A.jpgI have a small nest but only installed it because I wanted to raise the height. Used to have it straight on the stone with zero issues. I also used a Stoker with additional monitoring software and would not smoke without it. Actually looking at designing a newer cloud based version for better controls. The picture here is before I put it on the nest.
    18K IG Gunite Pool Florida GEM finish with attached Spa replastered May 2017. Hayward Salt System. Dolphin M500 and SolarBreeze NX. TFT-100. Hayward CX1750RE Cartridge Filter. Hayward H400FDP Propane pool heater.
  19. Back To Top    #19
    Arizonarob's Avatar
    Join Date
    Mar 2018
    Location
    Chandler Arizona
    Posts
    1,017
    If you guys haven’t noticed, Matt loves his BGE so much, he actually blow dries his hair whilst smoking meats. (See hair drier in his pic behind the egg)
    His wife has filed a restraining order against the BGE citing “bromance” allegations.
    ~Rob
    11,000 gallon in ground plaster pebbletech finish. Hayward Tristar VS, Hayward Swimclear, and Hayward Aquanaut 200 pool vac, K-2006 Kit, Speedstir.
    FC/CYA Chart-Finding a suction side air leak>https://youtu.be/eweIDTnJCUw
  20. Back To Top    #20
    Join Date
    Jun 2018
    Location
    Long Beach, CA
    Posts
    7
    [QUOTE=jimim;1539489]that's pretty cool. so it gives u the same indirect heat as the big green egg version? so the main thing with this is to give u multiple levels for more cook space pretty much?
    jim
    Yep. It uses the (pizza) stones to provide the barrier for indirect cooks. It is a really great and versatile setup. You can save some coin by not getting the conveggtor and just going straight to the Adjustable Rig. The extender is great for getting things high up in the top for raised direct/indirect cooks. Perfect for pizza.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
