Results 1 to 13 of 13
Thread: Determine the use of the second hole in my skimmer
  1. Back To Top    #1
    Join Date
    Oct 2018
    Location
    Canada
    Posts
    6
    I am closing my pool for the first time. I've figured out a good game plan for blowing out the lines, except I am not sure what to do with the second hole in my skimmer.
    Quote Originally Posted by waste View Post
    The second line can be used for 3 things (anyone who uses the first 2 is a moron )
    #1 A balance line (as per drjames) as was said it's a below water line that "supposedly" keeps the water in the skimmer at the same level as the pool. It's a great idea on paper but the pump is drawing more water than the atmospheric pressure can refill - hence, the skimmer doesn't refill, air is sucked into the line and the damage that this is 'supposed' to prevent happens anyway. (they are also a PITA to winterize!)
    #2 Plumb a main drain via the skimmer (as per Jason) - What a moronic idea!!! The valve in the skimmer to control the flow between the skimmer and main drain is highly susceptible to failure and if the main line from the skimmer breaks - you are SOL! Also, it's far better to have the suction lines separate - it allows more flow to feed the pump. It also has the same problem with keeping the skimmer 'fed' with water if the water level drops. It's also a PITA to winterize!
    #3 A reserve line - this is about the only option that makes any sense. When you plumb the pool you run 2 parallel lines from the skimmer to the filter pad, you only plumb one to the pump, but leave the other stubbed up (capped and plugged) to be used if the original line fails for whatever reason. The problem with this is that since the pipes are run together, what breaks 1 will probably break the other, unless it's freeze damage and the reserve line has been kept dry.
    As far as I know those are the only reason for the second port in the bottom of a skimmer, if yours is open it's not a reserve line.
    For winterizing it needs to have the water blown out of it and be plugged. If it is a balance line or a main drain line, let me know and I'll tell you a way to winterize it
    Based on this information, I think it is #2.
    If I blow air down this second line, if air comes out the main drain, I take it that means it is #2 ?
    I am going to try to blow out the line with my Shop Vac, is there any risk ?
    Vinyl Inground 80,000 Liters.
  2. Back To Top    #2
    Catanzaro's Avatar
    Join Date
    Jul 2014
    Location
    Monmouth County, New Jersey
    Posts
    3,204
    Re: Determine the use of the second hole in my skimmer
    Quote Originally Posted by KidneyPool View Post
    I am closing my pool for the first time. I've figured out a good game plan for blowing out the lines, except I am not sure what to do with the second hole in my skimmer. Based on this information, I think it is #2. If I blow air down this second line, if air comes out the main drain, I take it that means it is #2 ? I am going to try to blow out the line with my Shop Vac, is there any risk ?
    There is no risk with the shop vac. Although, you will have to trap air in the line. If this is the main drain, you may want to consider purchasing blow thru plugs with a Schrader valve. I do not know if they ship to Canada. The shop vac may not have enough air volume to accomplish the task. You will have to be very quick in plugging up the port. With the blow thru valves, an air compressor can be used.
    Blow-Thru Valve Winter Pool Plugs - Various Sizes
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
  3. Back To Top    #3
    Mod Squad Jimrahbe's Avatar
    Join Date
    Jul 2014
    Location
    Bedford, TX
    Posts
    9,867
    kp,
    Welcome to TFP.. a great place to find the answers to all of your pool maintenance questions, even if you live in the frozen North...
    If your pool is over 10 years old, the most likely scenario is #2.. One hole goes to the pump and the other hole goes to the main drain.
    I can't help with closing questions, because I live in a place where most of us don't close our pools.
    Let's see if we can get one of our closing experts to chime in..
    That said, I do not understand the theory of blowing out the main drain line when it is connected to the skimmer.. Seems like the water in the main drain line would be the same level as the water in the pool?? Also, unless you have a way to prevent water from flowing back into the main drain, it would just fill up the pipe again??
    I'll also be interested in the answers you get..
    Jim R.
    Finished in 2015 - 17K Gal, IG, 20' x 25' Almost Rectangular Pool, Pebble finish, three rockport water falls. Pentair Equipment: EasyTouch 4, IC40 SWG, 3 HP VS Pump, CCP520 Cartridge Filter.
    TF100 with SpeedStir and SampleSizer, ColorQ Pro 7, Dolphin Premier Robot Cleaner, added Screen Logic 2, added small 3 person Caldera Spa.
  4. Back To Top    #4
    Catanzaro's Avatar
    Join Date
    Jul 2014
    Location
    Posts
    3,204
    I always tell people to follow the plumbing. If there are 2 connections, one going down to the pool and the skimmer going back to the pump, both in the skimmer housing, then to clear the lines, air will have to be trapped in the main drain and water completely removed in the line from the skimmer going back to the pump. If not threads for a Gizzmo, either antifreeze for expansion or foam rope. The plugs with the valve work real well.
  5. Back To Top    #5
    Join Date
    Jul 2014
    Location
    Bedford, TX
    Posts
    9,867
    Quote Originally Posted by Catanzaro View Post
    Cat,
    So you add a plug with a valve in the skimmer and then use an air compressor to add air into the skimmer side, until all the water is forced out of the main drain pipe. Is that correct?
    If you don't do this I assume the water in the main drain line would freeze?? Does this mean that all the plumbing lines have to be dry when you close?
    I am worse than a new-be when it comes to closing questions..
    Jim R.
  6. Back To Top    #6
    Catanzaro's Avatar
    Join Date
    Jul 2014
    Location
    Posts
    3,204
    Cat,
    We have to figure out where the 2 skimmers ports go. The way I explained everything appears to be one run, when I believe they are independent of each other. I believe that if the skimmer level falls, the main drain works as protection. I would wait to hear back from the pool owner.
    Best way is to lower the water below the skimmer (with regular pump), then blow air and see which way it travels. If one port goes to the bottom of the pool, the main drain, then you will need to trap air in the line (blow tru plugs). The other line will need to be emptied of water either working backwards to the pump or from the pump to the skimmer. This is the beauty of lowering the water 1" below the skimmer.
    My knowledge is no different than yours. Today, I just added a schematic in my detailed closing thread that shows travel of air (See below). Then again, a combination skimmer (which I believe is somewhere linked in the thread) is not drawn out on paper. There are many variables with the skimmer/main drain combinations.
  7. Back To Top    #7
    Join Date
    Jan 2018
    Location
    Australia
    Posts
    339
    I have #2 and I agree it’s moronic. Our old pool we built had separate line going to drain and going to skimmer, which made vastly more sense.
    50,000L, IG (in ground), Concrete/marblesheen, 40 years old, Sand filter (Zelbrite media), Davey PM Eco (1600rpm), SWG, Clear Choice Labs Testing Kit, solar (25m2 tubes, Davey wisper 500 Boost pump), Zodiac vx50 robot cleaner
  8. Back To Top    #8
    Join Date
    Jan 2018
    Location
    Australia
    Posts
    339
    Re. The shop vac. I think you’ll struggle to push air down to the main drain!
    id just shove some food colour into the hole and plug a garden hose in there.
  9. Back To Top    #9
    Join Date
    Apr 2018
    Location
    Bangor Maine
    Posts
    435
    If the front line is plumbed to the skimmer, you just need to push in a 3-4 ft section of 1” foam rope, plug and move on.
  10. Back To Top    #10
    Join Date
    Oct 2018
    Location
    Canada
    Posts
    6
    Is there ever two lines from the main drain ?
    I think I have a line not being currently used (I have a picture at home) beside my skimmer line near the pump.
    So if my skimmer connects to the main drain, is it possible they would hook up two connections to the main drain ?
    Quote Originally Posted by tomfrh View Post
    If food colouring comes out the main drain, I'd have my answer. I'll try it ! Thanks.
  11. Back To Top    #11
    Join Date
    Apr 2018
    Location
    Bangor Maine
    Posts
    435
    If both holes were plumbed to the main drain there would be no way for the pump to draw water.
  12. Back To Top    #12
    In the Industry
    Join Date
    Jul 2017
    Location
    Windsor, Ontario. Canada
    Posts
    111
    Quote Originally Posted by Pool_Medic View Post
    There you go, that has worked for me now for 40 years.
    16 x 32 In-ground
    Steel walls with cement bottom and 8' deep end.
    Vinyl liner.
    1 skimmer with 2 holes, 1 to pump, other down to main drain.
  13. Back To Top    #13
    Join Date
    Oct 2018
    Location
    Canada
    Posts
    6
    Only had Soya Sauce. And that worked.
    My second hole is connected to the main drain, as that is where the soya sauce ended up.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
