So I've checked my pH repeatedly and I'm getting 7.3 with my calibrated pH meter. However, I don't think it's accurate because my reading (when using the attached image) is a bit different. I'm getting a 7.8 with this image. I'm about to throw my pH meter out the window. I mean, I calibrate this pH meter every time I use it, but for some reason, I'm not getting accurate readings with it. I'm just now noticing that my pH is high. Has anyone run across this problem...
my FC is 10.5... just tested it and my TA is 120.... petty much stays around 120 (though is does fluctuate sometimes at a +/- 10ppm).
Ugh...what should I do. I want to trust my eyes and just adjust my pH now or should I wait until my FC falls below 10? Not sure if it really matters at this point. "cause my pool is being closed on Wednesday and I need to get my pH in check. Just confused as to what's going on.
BTW: pool temperature is about 55 deg.
