Thread: confused as to what these stains are
    Sep 2009
    Burleson, TX
    21
    My hot tub has been getting these stains more and more frequently. I've cleaned them off with steel wool before, but they keep coming back.
    anyone know what this is?
    http://picasaweb.google.com/zaph0d.b...eat=directlink
    Re: confused as to what these stains are
    ick!
    It would probably help if we knew what you typically use to sanitize your spa, and other things you add to your water.
    I would suggest posting your latest test results, if you still have them, even tho the spa appears to be empty now.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Sep 2009
    Burleson, TX
    21
    that would have probably been a good idea to test the water before I emptied it....
    as for sanitation, it's pretty much just bromine tabs that I get from my local Lowes. I put a few in the floater and let it go for a week or so. That's about when the tabs have dissolved.
    I run the pump about 2 hours a day. The bromine level always reads just above 8ppm. It's rarely used...it was a freebie 4 years ago and I should have never accepted it
    Toads have taken up residence below the enclosure and every once in a while, one gets in and I'll have to fish it out. That's about the extent of it.
    Oh, and one other thing. Most of those stains are around the bubbler vents. I noticed one forming around a crack in the surface on the side wall. I noticed another one forming on top of a bubble underneath the surface of the side wall.
    Now I'm becoming curious as to why there are cracks and bubbles forming underneath the tub surface.
    Sep 2009
    Burleson, TX
    21
    I just figured out it dissolves away in a light (~1 to 8) muratic acid spray. Don't even have to touch it. It just goes away from the spray.
