Results 1 to 9 of 9
Thread: closing without cover
    Jul 2009
    Fort Wayne, IN
    392
    I thought I read somewhere on here that I don't HAVE to cover my pool in the winter. All the leaves have already fallen from the trees and I vacuumed for the last time. It is currently sparkling clean and my numbers are great. Can I winterized everything like I usually do, but leave the cover off this winter?
    thanks!
    Theresa and/or Gary
    Complete DIY: 20x40' rectangle. Resin walls, vinyl lined. 33000 gallons. Full width steps. 8' deep. Diving board, slide. Hayward pro series super pump, sand filter. Raypack 336K BTU heater. Main drain, 2 skimmers, 3 returns, 2 amerilite lights with quick change lens Aquamatic auto cover and a partridge in a pear tree.
    Breaking our backs in the hopes that one of our six kids will care for us when we are old ;)
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: closing without cover
    That might of been me. I did cover it this year, cover with water bags and leaf net over. For 4 years I didn't cover the pool. It was a swamp by spring, ducks, mosquitos, scum floating on top. Given my equipment it didn't long to clean up, about 4 days. It would take about 40 gallons of bleach, many backwashes, brushing and vaccuming. On many pools this could be a lengthy proccess and more work. If you can throw a cover on it, save yourself the aggrevation.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    New Brunswick Canada
    819
    On my fifth year with pool here, and I have never used a winter cover.
    All my neighbors do, and they all have tons of work in the spring, cleaning off covers and the like. My pool is the same clarity as theirs is. I scoop all leaves out as they come and then once freeze sets in, there is no more work until spring.
    For the life of me, I honestly don't know why the cheap pool covers are used, always falling in, water build up on them and all. If I was to use a cover, it would be the one that straps down and you can walk an elephant across them.
    Jul 2009
    Fort Wayne, IN
    392
    that was kind of my feeling about covers. I usually uncover the pool myself. I'm 5 ft tall and 103 pounds. I can't pull the cover off without all the nasty water and leaves falling in. Figured I would leave it open longer and fish out the leaves as they fall. I'm gonna go topless this winter...coverless I mean!
    thanks for the super fast advice!
    Theresa and/or Gary
    Mar 2007
    Coastalish 'down easter'
    4,160
    There are ways to remove the cover without all the 'stuff' ending up in the pool - but it's an industry secret that I'm not supposed to reveal (but since you're a 'lifer', I'll tell you, if you ask real nice :P )
    Luv& Luk
    -Ted
    819
    I believe that is just it, the mystery of how to run a pool, always concealed by PB's.
    When in fact its sites like this that truly reveal how simple the process is. Lets see, Pool Cover, Bags to hold Cover on (Supposedly), possible pillows to hold cover up, and then a possible pump to pump off excess water. Now on top of that, lets add a leaf cover, which in fact only stops full leaves, but as we all know, leaves tend to break down as they blow around. Go figure.
    Its like closing a pool, the big mystery of it all is so simple when one understands the process.
    A question I would like posed.
    How many Pool Stores have people there that own pools and how many of them are even educated in their field? Same goes for Pool Installation, one can sub contract (which is what most Pool Stores do) and get any pool done for 40% of what the actual costs are.
    I will never cover my pool, I enjoy once the water melts, to simply hook up all lines, turn on pump, vacuum once, and voila, my pool is ready to go.
    Jul 2009
    Fort Wayne, IN
    392
    Oh do tell! Please...pretty please!
    Theresa and/or Gary
    Mar 2007
    4,160
    Of course it's no big secret - all you need do is remove the tree debris and as much water as you can before attempting the cover removal
    A leafnet attachment for your skimmer/ vac poll makes the debris removal easier and you can either use a sump pump or a garden hose to siphon the water off.
    Once the cover is ~ debris and water-free, loosen the cable and fold the cover in half (towards the end you want to remove it from). Once it's folded so, pull the cover from the end, making sure that the sides of the cover stay out of the pool. It takes at least 2 people to do this (though one could probably manage it by them self - it'd take an hour )
    As you get your cover 'taco' to the end, you'll realize that 1/4" of water on the cover actually equals numerous gallons which are too heavy to lift You can either pump or siphon that water off or 'rock and roll' the cover - pull the cover as much as you can so that the water on the cover splashes out over the rail, repeat until the cover comes off Keep an eye out to make sure that neither of the cover folds are going in the pool! (It's easier to do it than describe how to do it )
    Sorry for the delay, I know I wasn't crystal clear in my description , if you need clarification on this, I'll be happy to further explain
    Luv& Luk
    -Ted
    Jul 2009
    Fort Wayne, IN
    392
    I'm handing this task over to my son and his friends! I will print these directions and sit back to watch the show! Thanks a bunch!
    Theresa and/or Gary
