Thread: Polaris Caretaker problem
    My pool pop ups havent worked in years (after the filter was changed 10yrs ago) all they did when i turn them on was make loud banging noise. So in the past month i repainted the pool and put new sand in the filter. I remover the caretaker and took it appart and found a couple of the gears seized up so i freed them up and all moves great now. when i got the pool running i turned on the floor cleaner and noise was gone but pop ups didnt work, pressure went up from 15 to 30 when i switched the floor cleaner on it started leaking from around the tubes that go in the ground. Question is could it be the leak around the tubes causing the pop ups not to work or maybe the seals inside around the pistons? also is that pressure a normal spike? Thanx all answers are appriciated
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Polaris Caretaker problem
    Quote Originally Posted by Mpswirl
    Hello Mpswirl... just posting to welcome you to TFP forum
    Hopefully some members who are familiar with your system can offer advice on the Polaris Caretaker in-floor cleaner.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    thanks polyvue this is a great forum
