Thread: In-ground Pool liner and coping replacement progress w/pics
    Sep 2009
    Southern California Desert
    28
    To recap, here is the pool in question. The liner is due to be replaced and the previous owner concreted over the automatic cover opening. Also, the original coping was set on a course of brick to increase its height which makes no sense. Also, the coping was mortared to the bond beam and butted to the deck which is a no-no from an expansion perspective. This is a total DIY project.
    Here are the original coping pictures:
    Now, here is the status:
    Pool coping choices are pre-cast concrete and poured concrete. Haven't decided but am leaning to poured. Either solution requires raising the bond beam to an acceptable level.
    Several outstanding questions:
    First, I need a source for liner track. Harder than I thought to find. I'm leaning toward horizontally applied for ease of replacement later on.
    Second, I'm going to replace the skimmer. Its 20 years old and I've found cracks inside. This is a concrete wall (8")constructed vinyl pool. What is the correct skimmer to buy? I think its a Hayward 10841, but I'm not really sure. I see that DanO has just asked about replacing a skimmer. His pool appears to be gunite, mine is vinyl but it looks like the advice given there is useful to me as well.
    Any tips on poured coping? I could use a lot.
    25000 gallon in-ground vinyl pool
    approximately 25 years old
    1.5 hp 2 speed pump DE filter Intellichlor Salt System
    Crappy 1.5" plumbing.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: In-ground Pool liner and coping replacement progress w/pics
    The only place I can think of is APC (Aquatics Parts Company) - the track won't be cheap
    The 1084 skimmer looks like what you'll want. Do follow the advice given to DanO (here) and ask questions as needed
    As for the cantilever (poured on) deck - I wouldn't attempt it for my own pool- it's much easier to use precast coping or brick/ stone, but if you know someone with lots of experience doing the cantilever decks, that's a different story.
    If you need any tips & tricks for installing either the receiver or coping, simply ask
    Luv& Luk
    -Ted
    Sep 2009
    28
    Thanks for the advise.
    I was able to find one distributor. 8 feet at $10, so not too bad. Took a bit of looking though. APC looks like its mostly for the trade, but I can give them a call in the next couple of days. Don't know if they do retail.
    A follow-on question on the track. What screws to use? Are they self drilling, or am I going around the pool with a drill in one hand and a driver in the other? Stainless, coated, what? It looks like 6" spacing is the recommendation.
    Regarding the poured coping. I think it would look better if done right. I'm calling around tomorrow to see if we have a local contractor who can do the pour. It would need to be a monolithic pour so that would require labor to haul enough concrete quickly. I live in a small town and we have few local contractors. We definitely don't even have a pumper truck so the concrete will need to be wheelbarrowed.
    I'm looking at pre-cast as well. A semi-local place can do 30" segments at a cost of about $16 per foot. Delivery is on me since its 120 miles away. This has a higher probability of sucess, but at a somewhat reduced attractiveness.
    I've kind of fallen in love with this pool coping concept I found on-line. Simple to form, elegant to look at. Don't know how it would look considering I'm keeping my existing deck. Forming it up looked simple. 2x material along the wall to create the cantilever, second 2x to form the inside wall. I would need to figure out how to attach to the wall though. Probably a bunch of concrete screws. Here is a pic and a reference...Maybe I'll be in love with something else tomorrow.
    http://www.aqua-shine.com/Index/Current ... 0_WSN.html
    At any rate, thanks for listening. Tomorrow is cut up the liner and remove the track day. Also the start taking the old concrete to the dump day. Thursday its supposed to rain.
    Sep 2009
    28
    Todays update:
    The liner is gone as well as the liner track. Not too bad.
    Is it normal for the liner to be brittle? Pretty much just cracked into large chunks. Its now in nice trashcan sized pieces. Don't think it can be recycled, so to the landfill it goes?
    New questions?
    Is this much algae normal under a liner?
    Also, tell me what I need to do with this lifting layer of plaster. I guess I got maybe 15 sq ft of hollow sounding areas in the walls. My understanding is that these liner pools are vermiculite/cement below the vertical wall. The under layer seems solid, but a bit soft. A tool will dent it. Same with the over layer. There are also areas that seem like they are repaired with something stronger like plaster or stucco mix. Not too much of that though.
    If I'm right on the vermiculite/cement, where do I get the vermiculite and what ratio to mix and what adhesion promoter to use if any.
    Sorry for so many questions, I literally have no local sources to lean on.
    - Michael
    are u doing the coping replacement yourself?
    That picture looks like a pour in place deck. you prob need to cut and remove at lease another 12 to 24 "of your decking to get a good clean coping form..
    Stegmeier has a liner track and form system. Looks like that is exactly what you need.
    http://www.stegmeier.com/SectionProduct ... gular.aspx
    here is a video too..
    http://video.google.com/videoplay?docid ... stegmeier#
    If I was u I would get precast Stepstone coping
    you have to order them from your local building material place. Not cheap but top quality stuff.
    http://www.stepstoneinc.com/images/deta ... 202008.pdf
    14000K gal 400sq ft w 6x8 spa, Pentair Intelliflo VS3050, Pentair cart filter, Pentair Master Temp, Pentair Intellichlor IC40, Pentair Easy Touch 8, wireless control. 3x intellibrite LED light. Pentair Kreepy Krauley Sand Shark. Solar Panel Plumbing. 2 x 24 inch arc sheer 24" spa spill way.
    Mar 2007
    4,160
    Have you ordered the new liner? I gotta tell you that it would take me over an hour to properly measure for a new liner for that pool
    I'm not sure what they used for the old patches, I assume that those are the white areas on the side walls?, but you'll want to 'sound' them and also dig out any 'soft' spots in the vermiculite
    The mix for vermiculite is ~ 2:1 cement: vermiculite - we use 1/2 bag portland (type I or II) per 16 - 20 lb. bag of verm. with ~ 12 gal. water
    If you need more detail on the mix, how to do it, 'sounding' the floor, et. al. simply ask
    You can use straight bleach to treat the algae on the floor
    Please continue to keep us informed
    Luv& Luk
    -Ted
