Thread: Winterizing Pool
    Winterizing Pool
    Hi,
    I have a question concering winterizing an inground vinyl lined pool.
    I removed the eyeballs from the filter returns and want to install the winter plugs. After I removed the eyeballs, the returns now have a large male threaded section. The plugs have a smaller male threaded section. I know these have worked before because I had the pool winterized professionally last year. There are outer covers around the threaded sections but it looks like there are screws going through them, so I cant imagine that I would want to remove them. If I feel inside the fittings I can feel a female threaded section that would fit the plugs but they are too far in to reach the threadson the plugs. Do I need to remove these outer collars? Will I be ripping through the liner if I try this.
    Your help is greatly appreciated.
    South Central NJ
    3,192
    Re: Winterizing Pool
    Hayward makes a flat plastic tool that fits inside the return fitting. If you put your finger inside it, you will feel slots it fits in. Many simply use needle nose pliers, spread wide into the slots, to unscrew them.
    Scott
    PoolGuyNJ
    Owner of - PoolGuyNJ LLC
    So,are you are saying that I do remove those collars that have screws in them?
    Thanks for your help
    South Central NJ
    3,192
    Standard Hayward threaded return fittings are a three piece design. You have removed two, the ball and the collar. The neck is still in place from what you have described. It needs to be removed. It's either slightly calcified or screwed in a little snug.
    Scott
    PoolGuyNJ
