Results 1 to 13 of 13
Thread: Blow out just deck jets (pic)
    We are going to try and keep our pool open through the winter. For now, we want to blow out just the deck jets and just the pool slide line. How do we just empty these lines and fill them with RV antifreeze, while leaving the other lines open? We are new pool owners and live in middle TN.
    The deck jet turn-off are the two red valves on the far left in the photo. There is another red handled valve on a line that is another little water feature, we need to winterize it too.
    The slide line concerns me because its turn-off is under the slide not at the pool pad.
    The plastic wrapper object on the far left is our new wood stove heater, delivered today and not hooked up, yet.
    Thanks
    Donna
    18X37 Grecian Vinyl Liner, X-Stream Slide, 1 1/2HP Hayward Pump, 3/4HP Polaris Booster, AquaRite SWG, Jandy AE3000 Heat/Cool, Jandy Deck Jets, 4.0 Colorlogic Light, Polaris 280 Cleaner
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Blow out just deck jets (pic)
    I don't know why you would want to do this but if you wanted to do it, I would put a pvc fitting past the shut off so you can hook a blower from there and then pour in antifreeze after your done.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    I want to winterize the deck jest only because I am most afraid of them freezing. They won't be running when I turn the pump on at freezing temps. The pipes for them are only under the concrete.
    Donna
    Mar 2007
    Coastalish 'down easter'
    4,160
    Not to be a 'Monday morning quarterback' , but that system is plumbed oddly I hope you're not using the CL220 trichlor feeder - it's plumbed in WRONG!
    It looks like you could disconnect the SWCG cell and blow out the water features that way, then add antifreeze at the poolside outlets and plug the lines (of course reclose the valves to them before turning the system back on )
    Have a good winter! If you need a little more info on what I just said, simply ask
    Luv& Luk
    -Ted
    I have attached a photo, without the leaves, of the T-cell area. After the cell, I see a larger T going into the ground. Is that the water that goes back to the pool returns? The next T is smaller, I believe that leads to the deck jets. The red cut-off there is just for a small feature we have. If I am correct about that, won't I be blowing all the returns and features, if I do it from the T-cell? I'm thinking this because I see no valve for just the returns. If that is true, I would blow from there then close the features off when the blow air and plug them, with or without anti-freeze. When the cell is hooked back up the water would then flow back through to the returns. I'm truly sorry if this is a really ignorant response.
    We kinda thought the plumbing was odd, but not knowing anyone with a pool we had nothing to compare to.
    We don't use the tablet chlorinator, but I'm still disappointed that it is plumbed wrong.
    We will be cutting into the plumbing for the wood heater, so if you see anything we could improve on top of the ground or around the pad, please let me know.
    Donna
    Donna
    South Central NJ
    3,192
    Post a picture of the deck jets. I want to be sure of which ones you have.
    Scott
    PoolGuyNJ
    Owner of - PoolGuyNJ LLC
    They are Jandy Deck Jets that have a plastic nozzel inside that screws off (pic). They come 4 to a pack.
    I am also concerned whether it will be possible to winterize the slide line without winterizing the entire pool (pic). The only cut-off I see for it is under the slide.
    Donna
    South Central NJ
    3,192
    As a professional, if I was paid to do this, there would be no warranty against freeze cracks with this system. It would have to be an or nothing. The same goes for when you are running to prevent freezing. All on or winterize completely.
    Scott
    PoolGuyNJ
    PoolGuyNJ.........I understand. We have purchased a dome and a wood heater to make it as long as we can into winter. We will most likely winterize the entire pool for the worst part of winter. We are just trying to protect the lines that will freeze more easily, now. This would be for any unexpected cold we might have prior to the hard winter and while we go on a two week trip. We don't want to worry too much about it while we are gone. Some nights can hover around freezing right now.
    Thanks!
    Donna
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by PoolGuyNJ
    Scott
    PoolGuyNJ
    I'm not a pool professional but I do agree about no warranty for certain things.
    Donna, where are you located?
    The very few times I've "closed" the pool, with pumping station below pool grade so pipes come out of ground to valves, I've used pipe heat tape (available at hardware stores and Wally World, for instance) on the pipes and wrapped well with insulation, especially the valves. I did drain out as much water as possible. You would have to have an electrical source to power the tape, of course. When we are having an especially "bad" winter I use electric tape on all of the pipes, insulated, and do the insulation over valves so that I can remove it/replace it to turn valves when needed. For the slide you would need to somehow get the remaining water out of the line leading up to the slide from valve, maybe blow the line from top and then quickly close the valve. Maybe putting some antifreeze in the slide line and cover it or close it off so that rain doesn't get into it.
    Although our winters are usually quite mild, there have been a very few when I still had freeze cracking, at below grade pump station, even though I had system running, but that was before I started using the heat tape and insulation.
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    I live in middle TN, near Nashville.
    I can disconnect the slide line to the valve.
    Donna
    Aug 2009
    North Central Texas
    1,358
    On one of my water spigots, with copper pipe coming up about 18" from ground, during extended freezes, I put a lot of bubble wrap around it then cover with a 5 gallon bucket. It is located, though, on the SW side of house, away from the harsh cold winds and it comes out of dirt and not concrete, if that makes a difference. I can even leave a few select, potted "tropicals" on that side protected by house and S fence, without much damage most winters. One winter we had temps hovering around 0 F for days (extremely rare). I used heat tape then on that spigot. That's one of the winters I kept the pool running, without heat tape, and had some freeze damage at pumping station. We even had ice in the pool. I put milk jugs in the pool and something similar in the skimmer. I started using heat tape regularly, at pumping station, after that. Last two winters haven't need that though.
    gg=alice
    South Central NJ
    3,192
    Disconnecting the slide wont do it. The main concern is at the equipment pad. There is no way to shut off the water to that line. It will refill.
    Scott
