Thread: Is that the right amount of Borax?
    Hi gang,
    I did a fresh fill for my spa and I'm using the BBB method (first time).
    So far, so good. However I do have a question about the use of Borax. I am assuming that on a fresh fill, the level is "0". I also have no way of testing the Borate level with my test kit. So, according to the pool calculator, I need to add 551 grams of Borax, followed by PH down (dry acid) in the amount of 352 grams. I've searched for measurement specs for Borax relative to grams per cup. I found one answer on the web that indicated 1 cup of Borax = 204 grams. That would mean I would require 2.7 cups of Borax to attain 50ppm for my 1,250 liter spa. Would that be correct? It just sounds like a lot of Borax.
    Thanks
    Peter
    1250L (330 US Gal) Max Spa - Chlorine
    Owned and operated since 2001 and still learning . . .
    BBB beginner
    Vero Beach, FL
    462
    Re: Is that the right amount of Borax?
    If you switch the units in the pool calculator to English up at the top, it then tells you how many oz by weigh and volume. Hover the mouse pointer over the oz reading and just below it will show it converted into lbs and cups respectively.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Quote Originally Posted by lborne
    Thanks for the tip on how to get the cups, etc information lborne.
    I went ahead and added a 2 cups of Borax and also the appropriate amount of pH down to compensate.
    My initial concern was the total amount of Borax required. The spa store supplied chemical such as SpaGuard Optimizer Plus calls for a lot less. However, I do understand that it is different than Borax. Just making sure I'm not reading things incorrectly.
    Regardless, the Borax has been added and I will be checking my pH and TA tomorrow to see what impact the Borax has on those readings.
    Peter
    BBB beginner
    Jan 2009
    Cupertino, CA
    1,966
    I used 2 cups borax in my spa, hit 50ppm according to the borate test strips. You should be fine.
    --paulr
    BBB "Intermediate Swimmer"
    Quote Originally Posted by PaulR
    --paulr
    Thanks Paul
    BBB beginner
